Procede and RB turbos
08-06-2012, 04:45 PM | #1 |
Rep 147
Hi,
I'm wondering if there will be a map for RB twin turbos in the near future. Yes, there is an aggressive map for upgraded twins but to be honest I'm not really impressed. The maps for stock turbos are great but I have a strong feeling that since the single turbo is out upgraded twins will not be supported anymore. And so far E85 is not supported for upgraded twins. Furthermore, it would be nice, if Vishnu can offer special maps for stacking tunes as well. IMHO it would be great to handle fuel control via Cobb and boost control + meth integration via Procede. What do you guys think?
[SIGPIC][/SIGPIC]
08-06-2012, 04:54 PM | #2 |
Rep 1,137
I would like to see some procede RB maps utilizing the new map sensor with upped boost. I think there is some room in there before 6k to run 23 psi...thoughts?
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
08-06-2012, 05:04 PM | #3 |
Rep 147
Some weeks ago Shiv said that upgraded twins won't benefit from upped boost beyond 20psi.
[SIGPIC][/SIGPIC]
08-06-2012, 05:13 PM | #4 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
I agree but until that happens (if ever), you know you can change the boost profile (at 500 RPM increments) using the advanced settings, right? I would do this in conjunction with data logging but many have seen benefits beyond the standard maps by doing this.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
08-06-2012, 06:23 PM | #5 | |
Rep 121
Fine tuning your tune to your car is the best thing you can do. You should talk to shiv about a map for YOUR car. You can also look into something like Cobb that can be dyno tuned for your car, I'm NOT dissing PROcede or anything like that but there other options that may suit your needs at this time. |
08-06-2012, 06:43 PM | #6 |
Rep 147
Thank you guys. I just want to wait until the new E85 maps are out. On the basis of these maps I hope Shiv can fine tune my car.
[SIGPIC][/SIGPIC]
08-06-2012, 10:18 PM | #7 | |
Rep 2,396
Drives: '08 E90 335i
If you go to the other forum, there's an in-depth explanation of how to do this |
08-07-2012, 12:41 AM | #8 |
Rep 2,172
+1 I'm really interested in how well the COBB will control the fuel because I'm making some really good numbers with e85 at 18 psi, but even with the Stg3 maps, I had to open up the OL tables a bunch to keep from maxing out the trims to include running lean... Virtual Dyno is showing 417 hp and 466 lbft using the Mustang Dyno. DynoJet 479 hp and 535 lbft.... Honestly, the butt dyno is telling me my car has never pulled harder from 3 to 5k, ever...
Hopefully the COBB guys at Surgeline will chime in, I live in Portland OR, so if any of the guys here wants to do some testing with stacking, shoot me a PM. I'm sure everyone else who owns a Procede and wants to run e85 would be interested in seeing how well this stacks up... |
08-07-2012, 01:34 AM | #9 | |
Formerly (-(ellblazer420
48
Rep 703
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
08-07-2012, 06:15 AM | #10 |
Rep 2,396
And not that there is anything wrong with flashing vs piggys (it's whatever works best for the user & helps them achieve their goals), but it does give you the ability to tune more in-depth. Shiv's come to terms that this was necessary for high HP on the single-turbo since the DME gets flashed specifically for fueling tables
08-11-2012, 05:56 AM | #11 |
1750
Rep 17,960
Drives: A Lot
If you need a higher fuel ceiling and higher rev limits, we can reflash your DME accordingly for $100. The higher DME boost targets combined with the PROcede OL Fuel adjustments gives it a much higher fuel ceiling than either approach alone. Same tuning approach used in our 700+hp single turbo kits. The RB turbos will run out of steam before your fuel system does.
More info: http://www.procedetuning.com/BMW/n54/tuner/tuner.html |
08-11-2012, 06:09 AM | #12 | |
Rep 1,432
08-11-2012, 06:15 AM | #13 | |
Rep 1,617
Sending in the ECU is not really an option for us overseas guys.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
08-13-2012, 05:29 AM | #15 | |
Rep 2,563
Or use the JB4 for which Terry also offers an additional flash (using COBB) for fueling, the piggy is then mostly in charge of boost control. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
08-13-2012, 05:58 AM | #16 |
Rep 7,377
+1 , best option right now for EU people
08-13-2012, 04:49 PM | #17 |
Rep 6,631
Although dialing in boost with ATR isn't for the faint of heart, even a nub like me could figure it out. IMO, stacking isn't necessary other than for methanol safety purposes and CAN integration (gauges, code clearing).
E90 LCI N54 6AT
08-13-2012, 09:52 PM | #19 |
Rep 2,396
08-13-2012, 10:21 PM | #20 |
1750
Rep 17,960
Drives: A Lot
If mailing a dme isn't feasible, one option is to wait a few months for another at-home solution. It should be more affordable/flexible that current at-home options. Regardless, next week I'll post up addresses for the tables that need to be altered for those running Cobb tunes. It will have to be up to the guys at Cobb to make these tables accessible via their tuning software.
08-13-2012, 10:22 PM | #21 |
1750
Rep 17,960
Drives: A Lot
08-13-2012, 10:23 PM | #22 |
1750
Rep 17,960
Drives: A Lot
