~~~~~~SETRAB Oil Cooler Mod~~~~~~
08-06-2012, 06:37 PM | #1 |
Not Baned
87
Rep 1,354
Hey guys Check it out!
Big Thanks to taylors335 for the Write Up. This is has been in the making for a couple of weeks now, I've just been waiting on all the parts and all. Finally got everything-in, put all the hoses together, fittings welded and BAM! Let me know what you guys think! P.S. I ended up going with a Setrab Oil Cooler just cuz i got a great deal on one... Before: After: |
08-06-2012, 07:35 PM | #6 |
Rep 381
doesnt matter since cars that dont have oem oil coolers just have plugs right there that you can screw out.
2008 335i 6MT
08-06-2012, 08:54 PM | #9 |
Rep 2,561
Nice! How much did it run? How was the install?
Montego Blue 2007 E92 335i - ZSP / ZPP / Steptronic / Logic7 Broadway Static - CCW - Megan - Orion Instagram: bmwforlife |
08-06-2012, 08:58 PM | #10 | |
Not Baned
87
Rep 1,354
08-06-2012, 09:00 PM | #11 | |
Not Baned
87
Rep 1,354
08-06-2012, 09:03 PM | #12 | |
Not Baned
87
Rep 1,354
08-06-2012, 09:17 PM | #14 | |
Not Baned
87
Rep 1,354
I have a Performance Steering wheel so I'm always monitoring my temps... Last edited by JMARS; 08-06-2012 at 10:17 PM.. |
08-07-2012, 04:31 AM | #15 |
Rep 2,563
Looks good. But very similar to the AR Design radiator, I think they're also using Setrab cores.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
08-07-2012, 02:49 PM | #20 | |
Not Baned
87
Rep 1,354
Here is the highest temp I got after a few spirited runs (45 min or so of driving) then some stop and go. Keep in mind IT'S HOT OUT!!! 96°!!!!!!!! Last edited by JMARS; 08-07-2012 at 03:11 PM.. |
08-07-2012, 05:24 PM | #22 |
Not Baned
87
Rep 1,354
(1) - Setrab Oil Cooler. I went with 50-619-7612 which is a 19 Row Series-6 Cooler, If I was to do it over I would get the 50-920-7612 which is the 20 Row Series-9 (3in longer)
(2) - 22mm-AN8 fittings threads onto the oil cooler (1) - Straight -AN8 Fitting (Drivers Side Hose End) (1) - 45* -AN8 Fitting (Passenger Side Hose End) (2) - 90* -AN8 Fittings (Oil Housing Fittings) (2) - Drilled Oil Housing Plugs (2) - 90* Pipe Thread to -AN8 (Chop off the Threads and Weld to Drilled Plugs **Make sure to dial them(mark them) in so they point in the right direction**) (4) - 4ft of hose Thanks prett much it. I used taylors335 write-up a reference... http://www.e90post.com/forums/showth...ght=oil+cooler |
