Meth Nozzle Leak?
08-06-2012, 06:40 PM | #1 |
Rep 56
Meth Nozzle Leak?
Moved meth tank and pump to trunk. Nice improvement to meth flow and I actually get to use map 4!
After the drive, popped the hood and this is what I saw. Dark parts on the pipe are wet. Should I be concerned? Any putty I could use to seal the leak? Last edited by MrHeavyFoot; 08-06-2012 at 06:44 PM.. Reason: Reduced image size |
08-06-2012, 07:39 PM | #3 |
3442
Rep 79,211
Prime the pump manually and see what is leaking. It's either:
-The line itself is cracked. -Line is not sitting in clean in the nozzle so you need to cut it straight and re-insert. -It's leaking at the threads which means you might want to use a little bit of teflon tape. |
08-06-2012, 07:48 PM | #4 |
Rep 1,948
Actually you may want to check the nozzles and ensure it's screwed in properly. In my case, one of the nozzles where a tad loose. I use a mix of boost juice so it stains when it leaks so i noticed pretty much right away. Tighten the nozzles on the jet adapter, all was good.
08-06-2012, 09:37 PM | #7 |
Rep 2,842
Does anyone think that the pattern of that wet area looks more like a blowby leak from the silicone hose behind the nozzles?
Sure way to know is if the area stays permanently damp/oily.......if it was meth it would evaporate fairly quickly and be dry in short order. Last edited by Ilma; 08-07-2012 at 12:40 AM.. |
08-06-2012, 10:55 PM | #8 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
Doesn't look like a meth leak to me. I have had a leak that sprayed meth all over my hood and never saw it until I replaced meth with 100% water and saw the water spots.
08-07-2012, 05:27 AM | #9 |
Rep 799
Drives: 08 335 silverback
i agree with this and the above, pattern doesnt look right, and meth dries pretty quick , id pull the hoses, plug the ends and purge to see if it is even a meth leak, looks like its oily and coming from that elbow coupler
FBO...METH...BIG TWINS
08-07-2012, 01:12 PM | #11 |
Rep 1,054
log to see if boost is leaking??
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
08-07-2012, 06:19 PM | #12 |
Rep 56
Thanks for all the replies and suggestions guys!
I'll go clean the area then drive hard and see what happens when meth sprays. I'm using 50-50 and hope I see something if I stop and check within a minute or two. I've tried priming the pump before, but leaks, if any, happen after the (fast-acting?) valve and that doesn't open until it gets instructions from the Procede I'm guessing. I'm also hoping it's not from over-tightening the nozzles! Already happened once when installed at the shop and I had to order two new nozzles from Robert. |
08-07-2012, 06:22 PM | #13 | |
Rep 56
Will meth and teflon tape cause problems? |
08-07-2012, 06:25 PM | #14 |
Rep 56
08-24-2012, 04:40 AM | #15 | |
Rep 56
Cleaned the area, wiggled the pipe and tightened it some. It's been almost a week and the area is still clean. No leaking nozzles Thanks for the help guys! |
