What engine oil will you use?
05-19-2005, 07:24 PM | #1 |
Rep 51
Drives: E90 325i
Just wondering how regular do you change your engine oil and which brand do you think suits best for our BMW engines? If I'm not wrong, BMW recommends Castrol...
05-19-2005, 07:56 PM | #2 | |
Rep 2,099
05-20-2005, 06:38 AM | #5 |
Rep 51
Drives: E90 325i
Thank you for all the recommendations. Will try it when my next oil change, probably 10,000km or earlier...cheers
05-20-2005, 06:55 AM | #6 |
Rep 135
Previously, BMW has used Castrol as their OEM lubricant supplier. Not sure if that still holds (probably so). Mobil1 is well known and good stuff. Personally, I love Amsoil and have used it with great results in past and current cars. But it would be hard to go wrong with the OEM oil - I think it was Castrol synthetic on the E46.
05-20-2005, 07:05 AM | #7 |
Rep 10,185
BMW has recently changed their reccomendatio to their spec LL04, currently only Castrol and Mobils new " low emmisions formula" conform to it
Spec LL01 is still allowed in the E90 at the moment and the top of the range Mobil 1 does conform to it Dealesr here use Castrol TXT LL01 5W-30 exclusively for non M cars and will soon change to either the new Castrol SLX LL04 0W-30 or the soon to be introduced Castrol TXT LL04 5W-30 |
05-20-2005, 07:29 AM | #8 | |
Rep 135
05-20-2005, 09:04 PM | #9 |
Rep 51
Drives: E90 325i
On my previous ride, E46, I'm using Mobil One and my local workshop did recommend me using Amsoil or OWS.
07-18-2005, 11:53 AM | #12 |
Rep 817
Drives: Porsche 991.2 Carrera S
I have always used the recommended Castrol in my E46.
09-26-2005, 08:30 PM | #13 |
Rep 805
You guys think it's ok to use Amsiol 5-W30 for my first change at 1250 miles and then use mobil 1 there after? Reason I'm asking is I have 7 quarts of the stuff left. Is it bad to mix synthetics? If so I'll just save the Amsoil and by what eer the dealer will use.
