335xi FBO/Cobb vs H/C/I ls1 camaro (vids)
08-06-2012, 09:39 PM | #1 |
Rep 610
So a few of my friends and I got together and decided to get some runs in at No Limit Raceway in Indiana since I'm home this weekend. I was going to bring the Turbo Trans Am but fried my 3-4 clutches,,,,again,,,,, 4l80e with a trans brake on the way
First it should be said that this track sucks when it comes to prep. We showed up and tech'd in early. It's a pretty quiet track so getting runs in is easy. We had some issues with my buddy Jay's nitrous spraying properly which we were able to fix later on. I had a few good runs. My best run was against Jay although he was spinning a bit and nitrous no worky. Ambient temps were 84 degrees and DA was about 2400. Willizm - 335xi - 6at - air filters, chargepipe, downpipes, FMIC, and Cobb AP stage 2 +fmic aggressive on 93 octane Hugger1975 - Z28 - 6mt - H/C/I, 9" spool, Enjoy. I didn't think I could even hang with his car, but even with all the disadvantages of crap prep and nitrous not working his worst pass still beat my best pass. I slept the light a bit and that cost me. I'm happy with my sedan though. Overall I was running consistent 12.6's with a 1.8 60'. Jay was getting a bit faster once we got the nitrous running properly. So this begs the obvious question. In cooler temps what else could I do to get this thing low 12's and possibly dipping into 11's? Not going to do weight reduction or reworked turbo's.
335i - stock for now
Escalade - Urban Assault Vehicle T/A - Forged ls1, PT8285 turbo, heads, cam, 4l80e w/Transbrake, s60 rear on e85. |
08-06-2012, 09:51 PM | #3 | |
Rep 2,396
Drives: '08 E90 335i
The AWD is killing your power:weight ratio, but it's probably helping a lot off the line. IF you really want to shave some time, consider stripping some weight by removing the rear seats |
08-06-2012, 10:03 PM | #4 |
Rep 699
Drives: e90 335i f30 330i g20 m340i
Stack a JB4 on top of your Cobb and run METH
My car is an addict. This will put you at a 12 flat, conservatively. It can be done inexpensively too- used JB4s aren't hard to find and you can piece together a TRUNK kit for just as inexpensive. I believe it was dzenno that did a good DIY on stacking Cobb & JB4. Lots of high power guys do it, relieving you of the feeling that you're taking an unknown risk. |
08-06-2012, 10:11 PM | #5 |
Rep 374
Nice job man! And good work not looking like a child racing on the streets.
2008 335xi AT
Cobb AP stage 1, drop in filter, the rest stock 13.10@106.01 w/ 1.86 60' (5,800' altitude) |
08-06-2012, 10:13 PM | #6 |
Rep 610
Btw this pass was a 12.5@111mph
08-06-2012, 10:16 PM | #7 | |
Rep 610
08-06-2012, 10:24 PM | #8 |
Rep 2,396
We can't run straight E85 yet (no aftermarket fuel pumps or upgraded fuel injectors), but if you tune for a mild-blend of E85 (25-30%), you'll get a very nice increase in power with almost zero timing corrections
08-06-2012, 10:54 PM | #9 | |
Rep 699
08-07-2012, 06:48 AM | #10 |
Rainbow Racer
1008
Rep 2,540
+1 on the near zero timing corrections, makes every map feel stronger.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
08-07-2012, 08:27 AM | #11 |
Rep 610
Well what would you guys do if you had the following in your garage at your disposal? I have backup e85 for my TA plus all my stuff for methanol that I removed when I went cobb. I sorta dropped out of the n54 world because I was getting my Turbo TA wrapped up and tuned on e85 so haven't really seen the latest developments.
5gal of e85(90% ethanol) 5gal of e85(87% ethanol) 5gal of MS109 5gal of M1 Methanol JB4 PNP standard board FSB WW meth kit Cobb AP Plus keep in mind my 335xi is FBO with stock catback. I'm looking to do one last hurrah before putting the 335xi on purely DD status. I also have a 135i that I want to get into more road course stuff and of course my TA for the strip.
08-07-2012, 09:13 AM | #12 | |
Rep 2,396
E85 (as you know) runs cooler & offers tremendous gains on turbo'd cars. It's also significantly more cost effective than running Race Gas (only downside is MPG loss, which I don't think is a make or break thing on a track focus car). You can tune your the 135 to run a decent e85 blend (35%), but anything higher will prob cancel out the benefits. The biggest problem with the N54 is that we don't have Aftermarket Fuel Injectors or Fuel Pumps currently available -- creating a restriction on how much E85 we can use before it diminishes performance. Like I said in an early post, contact the guys at ProTuning Freaks --- they're N54 specialist & will be able to not only give you a great deal on a tune, they'll be able to share their knowledge on what would be the ideal fuel blends for street + track performance. Last edited by benzy89; 08-07-2012 at 09:38 AM.. |
08-07-2012, 09:29 AM | #13 |
Rep 610
^I am leaning toward the e85 blending and willing to do some data logs and such. I'm just trying to figure out what is the best way to calculate the blend. I can try to get a rough estimate by calculating the remaining 93 octane in my tank based off of MPG and miles remaining on the cars display, but not sure if that is accurate or if there is a better way you guys do it. i test my e85 and have a station about a mile from my house that has great e85(anywhere from 85-90% ethanol). I would look for a good 93/e85 tune from PTF to have for track days and such, but then just run a 93 map for most of it's DD use.
08-07-2012, 09:36 AM | #14 |
Rep 2,396
Jake@PTF & I agreed that a 3.5 gallon blend (between 20-25%) would be ideal for me since I use 93 as a base fuel (would've gone more aggressive if I only had access to 91). I usually just fill 1/2 way with 93, add my 3.5 gallons of E85 & then top off with 93. I love it, the car pulls significantly harder than my ProTune Pump Gas map. Only downside is the nearest E85 pump is ~20 mins from my house
08-07-2012, 12:26 PM | #16 |
Rep 2,590
Not being a debby downer but don't forget he is an xi.
1.83 is only decent and can easily be cut to the low 1.7x consistently with the xi. After some practice and track prep, you can get to the mid to high 1.6s consistently. That will help out big time since our xi's lose a lot on the back 1/8th of the quarter mile compared to the i guys. Good run either way. |
08-07-2012, 12:33 PM | #17 | |
Rep 610
08-10-2012, 12:26 PM | #18 | |
Rep 370
If I were you, being that you've been out of the scene for a while, I'd ditch the Cobb and do the free 15ohm upgrade to the JB4 and reinstall it with the meth kit! I was happy when I ditched my Cobb 5 months ago, and the JB4 firmware has gotten much better since then! Just load up the latest firmware that automatically adjusts to E85 mixes and I bet money you will not miss the Cobb at all! The newest firmware is butter smooth, and VERY powerful, especially when running mixed E85 and 93 octane with a small shot of meth Check out my best time/mods in my signature... that was done back in April when Terry first came out with the new firmware for E85 and I was running 30% E85 on the old JB4 board... he has since updated the firmware a couple more times (it got better every time) and now I'm also running the new G5 board with a 50/50 E85 mix and the car is insanely fast! I cant wait to get back to the track soon! P.S... and don't be afraid to launch that xi a little harder next time... that last time I was at the track, my worst 60' of the day was a 1.71
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
08-10-2012, 04:41 PM | #19 | |
Rep 610
almost 90% ethanol less than a mile from my house. Viva la Shell!!
