is there an ATR map sharing thread?
08-13-2012, 10:06 AM | #2 |
Rep 6,631
It's not physically possible to share maps directly with ATR since the compiled maps are tied to the AP serial. The best we could do is copy and paste rows and columns or even whole tables to mimic someone's settings.
E90 LCI N54 6AT
08-13-2012, 10:20 AM | #3 |
Rep 121
Actually, you can share maps assuming they're of the same ROM revision. Just open your version of ATR and load the shared map you downloaded. Then if you want to use that map you just have to save it and it will then have your serial # and it will be able to be used.
08-13-2012, 10:25 AM | #4 | |
Rep 6,631
Most of us have IJE0S or I8A0S so there should be very few issues.
E90 LCI N54 6AT
08-13-2012, 11:17 AM | #5 |
Rep 121
I'm assuming that different ROMs can't be shared due to the smalls differences in some of the tables, it may be able to convert that when loaded into ATR. I've never shared a map with someone of another ROM so I can't say for sure. There are a couple maps in the Cobb & e85 thread and the one I made for flexinator is I8AOS, it would be cool if someone that is a different ROM would download that and see what happens.
08-13-2012, 02:19 PM | #7 | |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
Works just fine.
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
08-13-2012, 02:29 PM | #8 | |
Rep 639
08-13-2012, 02:56 PM | #9 |
Rep 1,037
let the sharing begin (subscribed) lol
someone point me to a stg1+ (tweaked) map
08-13-2012, 03:11 PM | #10 |
Rep 650
I'm kind of curious about people wanting maps based on Stage1 or Stage1+. Once the boost and timing are cranked up isn't it more aggressive than all the OTS maps? If so, does it really matter if it originally was a Stage1+ map?
08-13-2012, 03:29 PM | #11 |
Rep 121
The current +FMIC maps have the boost oscillation fix. Its better to let Cobb do all the base map work and we just start throwing boost and timing at it lol
08-13-2012, 03:42 PM | #12 | |
Rep 121
Also, that map is pretty mild and won't make as much power as possible. It's just a decent starting point. |
08-13-2012, 04:11 PM | #13 |
Rep 650
Oh, OK. I was looking at it from the opposite direction...I thought people were saying that they didn't want one based on Stage2+ and I was thinking "who cares"?
08-13-2012, 10:05 PM | #14 |
Rep 473
I wish the cobbs alpha race maps weren't locked and could be shared!
Cobb JR Tune, HFS-4, DCI, AMS Intercooler, Vishnu CP, Forge DV's, AR DP's, RPI exhaust, AR OCC, BMW STS, Spec stage 3+ clutch, CDV delete, H&R Coil overs, Quaife LSD, DefiV Lock down kit, WOTbox.
-SOLD |
08-13-2012, 10:23 PM | #15 |
Rep 121
Just for conversations sake, here's a datalog my ATR FBO+ 50/50 meth map.
It is a pretty aggressive map and IF you want it i will email it to you, however please PM me. I dont want to post it up and someone download and just goes for it without the supporting mods or meth. As i said it IS pretty aggressive and my car loves it but yours may not. IT IS I8AOS IF YOU PM ME AND ASK FOR IT I WILL HAPPILY GIVE IT TO YOU, HOWEVER I ASSUME ABSOLUTELY RESPONSIBILITY IF YOUR TURBOS EXPLODE, YOU HPFP SHOOTS OUT FROM UNDER THE HOOD, YOUR CRANK WALKS OR YOUR DIAMOND PLATE FLOOR BOARD FALLS OFF OR ANY OTHER DAMAGES THAT RESULT. rename as a .csv and have a look. Last edited by cloud_connected; 08-13-2012 at 10:28 PM.. |
08-13-2012, 10:28 PM | #16 | |
Rep 483
08-13-2012, 10:38 PM | #17 |
Rep 121
On a dynocom dyno it put down 400rwhp/460rwtq. A 125rwhp/160rwtq delta over stock on the same dyno. The stock dyno was done in feb and ambient temps were in the 40s and 30% humidity and last week when i re-dyno'd it was 86F and about 60%. When the temps cool back down i will try a balls to walls glory run
08-13-2012, 10:42 PM | #18 |
Rep 474
You had me piqued until I realized the potential danger to manifold!!
//ecg//
08-13-2012, 10:42 PM | #20 | |
Rep 473
I have IJE0S and run 70-30 meth. I had my car protuned and it doesn't feel right. I had them do some adjustments as well car but the car still feels like its pulling timing. I have two data logs from before they added the adjustment. I have yet to re log it though since "adjustments" have been made. If you PM me your email Ill send you them to take a look at.
-SOLD |
08-13-2012, 10:48 PM | #21 |
Rep 121
08-13-2012, 10:54 PM | #22 | |
Rep 121
