E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Code 11510 and bad idle oscillation on startup?
Reply
      08-14-2012, 03:10 PM   #1
Tronner
Drives: 2018 X3 M40i
Has anyone else seen code 11510? Every other day or so, I get a crazy startup idle oscillation that is really bad. The car pulses terribly for about a minute then finally settles down with half engine light on. Once it calms down the light stays on but the car seems to run fine although of course I haven't pushed it at all, just cruised home. Shiv said it's related to throttle valve potentiometer plausibility, which could be a vacuum leak. Where should I start looking? Here is a video when the idle is actually starting to calm down. The first 10 seconds are so are more representative of what it's doing. It's much worse at times.
http://youtu.be/VJNALDxZX0k
      08-15-2012, 03:26 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
search is your friend: http://www.e90post.com/forums/search...rchid=23372199
Reply
e90post
