E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Procede Pwm methanol kit and stett charge pipe..
Reply
      08-16-2012, 10:23 AM   #1
chiefsotos
chiefsotos's Avatar
42
Drives: BMW 335 E93
I have the stett charge pipe with dual cones intake and wonder if the procede pwm kit is compatibble with it.
Has anyone tried?
      08-16-2012, 10:55 AM   #2
ttbmer
Drives: space gray on black 07 335i
Yes u can use any charge pipe, u just need to have 2 meth bungs or add 2 if the CP don't have any.
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
      08-16-2012, 11:00 AM   #3
OpenFlash
Drives: A Lot
the Stett charge pipe is pretty small diameter and, the last time I checked, it has the nozzle bungs in an undesirable location. If you are to use it, install the meth nozzles as far upstream as possible. Even in the pipe between your FMIC and charge pipe, if feasible. And make sure the nozzles are located reasonably far apart from each other to avoid puddling effects.
      08-16-2012, 12:20 PM   #4
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
^ Correct.
The stett implemented the nozzles to close to the Throttle body for this application and aquamist bungs won't fit.
OP you would need to have new bungs put it in closer to the intercooler. You would need 2 aquamist bungs.
You may be able to find adapters but your nozzles would still be too close to the TB to take full advantage of atomization.
      08-16-2012, 01:34 PM   #5
chiefsotos
chiefsotos's Avatar
42
Drives: BMW 335 E93
Thank's guys
Reply
e90post
