almost killed a child with my cars smoke
08-16-2012, 10:10 PM | #1 |
Rep 240
UPDATE***** re-cap. car is blowing blue smoke, and a lot of it. go through oil at a quart a week. posted this question of what could be causing it and you see the replies below. the forum conclusion was 1.) PCV valve or 2.) blown turbos/turbo seal. car is in the shop for two days so far.
turbos replaced. upon inspection there really wasnt much oil in them...not enough to blow smoke like that. cant be PCV because i had a new valve cover put on a month ago. mechanic doesnt feel like it was the turbos (i wanted new ones anyway). will update again if a solution is found but it doesnt as of now seem to be the two things everyone thought it was. im running a stock cobb map so if its just running rich idk how thats possible...mainly blows smoke when i come to a stop. none on start up.
e92 335i sport[/B] 2 GO: Cobb AP Stg 2+, Macht Schnell DPs, Injen intake, Spearco FMIC, Velocity throttle booster, DBA 4000xs rotors, Vibrant Performance catback, Synapse BOV & charge pipe, Hancook V12 EVOs 4 SHOW: DCT paddles, cusco strut, piano black trim, Mtech bumper, aero lip, 19" Miro 111's, angel eye, black: window trim, side mark, kidneys Last edited by tmurphy2; 08-30-2012 at 08:07 PM.. |
08-16-2012, 10:13 PM | #2 |
Chump
10
Rep 173
Abnormal for sure. Blue = oil. I'm fully catless, no smoke, just exhaust smell (love it)
I used to have a turbo scion tc, blue smoke when stopping = blown turbo seals or something else leaking oil into your exhaust path.
2009 e90 LCI Blacked Out Space Gray - Vishnu Procede 2.5 w/9-10 Aggressive Map Stg2 - PWM Meth (80%) - BMS DCI - VRSF Intercooler - VRSF Downpipes - HKS Cat-back Exhaust
08-16-2012, 10:17 PM | #3 |
3442
Rep 79,211
I've mentioned in other threads about this it does not sound normal but appears to be quite popular on this platform, especially as the platform gets older.
I expect black smoke/soot under hard acceleration fully catless, but I dont any smoking slowing down. Blue is oil. black is usually unburnt fuel. |
08-16-2012, 10:57 PM | #4 |
Rep 6,631
I get white smoke especially in the winter on cold start, but it subsides pretty quick. I would guess it's all the condensation sitting in my muffler.
I get a puff of blue/white smoke on hard acceleration but apparently it's normal for RB turbos. I had none of these "issues" before I went fully catless.
E90 LCI N54 6AT
08-17-2012, 01:06 AM | #5 |
Rep 374
OP - one or both turbos a done. Blowing oil. Sorry to say.
2008 335xi AT
Cobb AP stage 1, drop in filter, the rest stock 13.10@106.01 w/ 1.86 60' (5,800' altitude) |
08-17-2012, 06:46 AM | #6 |
Rep 232
try putting it in neutral when coming to a stop,then back in drive
it will avoid back pressure and almost no smoke
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
08-17-2012, 07:16 AM | #7 |
McB Autosport
10
Rep 125
Your turbo seals are going bad. When I upgraded my turbos, The smoke went away. I run full catless, upgraded turbos and meth. No smoke at all!!
08-17-2012, 10:18 AM | #8 |
Rep 54
I have smoke on start/warmup on bank one, but drive it about a block smoke is gone. I'm running AR catless and straight pipes. Pretty sure it's a turbo seal.
08-17-2012, 10:51 AM | #11 |
Rep 2,396
Drives: '08 E90 335i
Blue Smoke = Oil = At least 1 of the Turbos are Starting to Die
White Smoke = Water being heated up & evaporating in your exhaust GL |
08-17-2012, 11:05 AM | #12 |
Some dude
92
Rep 1,780
Turbo seal is a definite possibility. Put the car up and pull the charge pipe going into the intercooler and the midpipe off the downpipes. Check for excessive liquid oil in the intake side or oil/lots of white burned powder in the exhaust side.
It could also be excessive oil pulling from the PCV. The valve cover houses most of the PCV system, and if it fails, it can suck excessive crankcase vapor and even liquid oil into the intake ports on decel (lots of manifold vacuum). The valve cover and labor is cheaper than a turbo, but have a shop check it out to determine what is bad.
RRT
E92 335i/6MT with stuff and things |
08-17-2012, 11:12 AM | #13 |
Rep 1,731
Two scenarios. Both costly, but you could DIY.
1) Valve Cover Gasket (VCG) leak. Check your PCV valve and the pipe leading to it. Oily? Valve Cover Gasket leak. Troubleshoot: Get the RB PCV valve and new pipe from the dealer. Check your oil cap, oily/gunky? VCG leak. Check for oil droplets around the block. Yes? VCG leak. Solution: Replace the gasket. If DIY, follow the Bentley book for recommended sealer, torque specs, how to, etc. 2) Turbo Seals Check your tailpipe, LOT of oil buildup? Like you can see oil on your exhaust tips? Seals are bad. Solution: Throw on cats (temp solution), smoke goes away...but you know your turbos are on their way out...albeit slowly. Get replacements (OEM) or upgrade to RB turbos (might as well...) How I know? My car used to SMOKE like CRAZY. I welded in cats in the midpipe, wha-la no smoke. I have c**less downpipes, and I didn't want to go back (that's where the most gains are). My smoke wasn't even on one side, it was on both. The cats just catch the oil and burn it through before the exhaust hence you didn't see it when catted. My 2 cents. Last edited by cityazndan; 08-17-2012 at 11:14 AM.. Reason: Clarification. |
08-17-2012, 01:18 PM | #14 |
Rep 4,444
As other's have stated it's not normal.
Also, as other's have stated, sounds like it's time to look into new turbos. I am fully catless with divorced piping all the way back and have almost nothing out of the exhaust. |
08-17-2012, 01:40 PM | #15 | |
Rep 887
I have alot of soot built up on my exhaust tips... it's all dry (don't see any liquidy looking oil) but are you saying the build up is from blown turbo seals? i have catless DP's as well but still have my secondary cats |
08-17-2012, 01:54 PM | #16 |
Rep 1,731
The soot is ok (just means you're running a bit rich...MUCH better than running lean, plus the gas smell is nice :]). What I was referring to was an oily residue or basically oil dripping from the tailpipes.
It got to the point my car would still continue to smoke a bit even AFTER I turned off the car. When you go catless, it takes longer for the pipes to heat up to burn off the excess oil. |
08-17-2012, 03:32 PM | #18 | |
Rep 64
I'm getting lots of white smoke from exhaust as well and only on start up from hot engine; goes away when cruising. Where is the water located and is there a fix to this? |
08-17-2012, 03:35 PM | #19 | |
Rep 10,587
there is no need for a fix
08-17-2012, 03:42 PM | #20 |
Rep 317
I been noticing a lot that I occasionally will get quite a bit of white smoke coming out both my exhaust after strong pulls and then coming to a full stop a street lights or even under normal driving conditions. From little research I did, most people say its due to carbon build up and the white smoke is from it burning off.. so I migh clean it and get it done.
Any other members experience this, and would you say its caused from carbon build up?
2007 E92 335i - JB4 / AR Catless DPs / ETS Chargepipe / HKS SSQV BOV / AFE Stage 2 DCI / MagnaFlow Exhaust / LUX V3 Angel Eyes / H&R Race Springs / Too Many Cosmetic Upgrades to List
08-17-2012, 03:49 PM | #21 |
Rep 1,708
Smoking is fun... every oil change / seafoam day I get excited. Last one was awesome with a smoke screen that made cars pull over and slow down. I need to video next time.
I had smoke when I went to a less restrictive exhaust and no cats... then I replaced the factory exhaust, but with gutted cats and the smoke disappeared. Backpressure plays a part. |
