Trying to figure out if I got post shift timing drops
08-18-2012, 08:55 AM | #1 |
Rep 368
I know u will tell me to log but I have had nightmares with connecting procede to laptop. I know there is a gauge mode that shows ignition correction. Is it mode 4 and what should I look for at a wot shift. It feels like a timing drop bc when I hit the kick down and the car does the second shift the power drops for a sec and then comes back on. And if I am having a drop what should I adjust in the parameters. I am on stage 0 on the latest 5-23maps. Thanks
Procede rev2.5se;Er Fmic; BMW PE
08-18-2012, 09:15 AM | #3 |
Rep 7,377
yeah log it lol
08-18-2012, 09:20 AM | #4 |
Rep 368
Grr. The only way I have connectivity is procede directly to laptop serial port. My serial to USB cable does not work. How much psi should I be seeing though. I spike to 15 psi and the taper down to about 12 psi from about 5600 rpm to redline.
08-18-2012, 09:25 AM | #5 |
Rep 6,631
sounds right but you are asking about timing post-shift, not boost. post logs. make sure CAN Actual Ign Adv is logged.
E90 LCI N54 6AT
08-18-2012, 09:32 AM | #6 |
Rep 368
Yup just making sure I am hitting boost targets. Still need to figure out this dam cable. Greer. Sure I can use the guage hijack to assist?
08-18-2012, 09:40 AM | #7 |
Rep 6,631
no, if you want someone to help here, you need logs. The gauge is CAN DME Ign Adv, which isn't "real" timing after the CPS offset calculation provided by CAN Actual Ign Adv. Otherwise it's all guessing.
E90 LCI N54 6AT
08-18-2012, 09:52 AM | #8 |
Some dude
92
Rep 1,780
Been using a Radio Shack USB converter, no drops. Set to 19200 bitrate, and deselect the option under the advanced settings for "use FIFO buffers (requires 16550 UART)" or something like that. All of that is under the Device Manager, LPT/COM port settings. Oddly enough I can't get the Vishnu recommended USB converter to work at all. This is on an old Vista / AMD laptop.
RRT
E92 335i/6MT with stuff and things |
08-18-2012, 10:24 AM | #9 | |
Rep 368
08-18-2012, 10:25 AM | #10 |
Rep 368
gotcha. Gotta figure out via logging. Understood.
08-18-2012, 10:35 AM | #11 |
Rep 2,842
My 2 cents is that a post shift timing drop will not feel like bog or lag......the acceleration continues smoothly, but feels kind of dull and does not pull as hard. From your description it sounds like transmission sorting something out or you are getting massive throttle closure on the kickdown.....neither of which is timing related.
But yeah....a datalog is going to point you in the right direction. |
08-18-2012, 11:52 AM | #12 | |
Rep 368
08-19-2012, 02:32 PM | #14 | |
Rep 368
08-19-2012, 02:50 PM | #15 | |
Rep 6,631
E90 LCI N54 6AT
08-20-2012, 07:29 PM | #16 |
Rep 368
Yeah but how am I gonna get the Cable out of the ecu cover with it closed?
08-20-2012, 07:35 PM | #17 | |
Rep 6,631
If you don't know what I'm talking about, you didn't install the tune yourself, did you?
E90 LCI N54 6AT
08-20-2012, 07:37 PM | #18 |
Reborn
87
Rep 1,217
08-20-2012, 07:55 PM | #19 | |
Rep 1,054
1. On either side of the white ECU box, there are wires coming in and out through rubber grommets. Pull the grommet on the right up, and use a pair of sharp scissors to cut a single slit through the grommet. Feed the wire through the slit and then push grommet down into its original position. 2. Don't latch the sliding locks at the top and bottom of the white ECU box. That way, you'll easily be able to pop the side latches on the right side, and reach inside to pull out your cable.
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler http://www.e90post.com/forums/showthread.php?t=782212 |
08-21-2012, 05:47 AM | #20 |
Rep 368
Yes I did. Man your answers are always cynical on this forum.
08-21-2012, 05:49 AM | #21 | |
Rep 368
08-21-2012, 06:54 AM | #22 |
Rep 1,054
No worries brotha. Do you play cricket, cause you just bowled 'em
