No Boost! This sucks
08-18-2012, 09:51 AM | #1 |
Rep 2,590
Everything was going great then all of a sudden my 17psi of boost drops down to 9. Now a day later I literally have no boost at full throttle.
I checked IC connections and replaced a few vac hoses but still need to do a leak test. I only get the 30ff code if I push the car full throttle. Any suggestions? Also, this run is on map 0 with the Procede. I dont understand why throttle and some things are just flatlined and not logged? |
08-18-2012, 10:10 AM | #2 |
Rep 7,377
yeah you have probably a leak somewhere.
08-18-2012, 10:13 AM | #3 |
Rep 2,590
08-18-2012, 10:14 AM | #4 |
Rep 7,377
you get no boost when it goes into limp mode.
08-18-2012, 10:16 AM | #5 |
Rep 2,590
I wasn't in limp mode right away, that was the start of the 3rd pull when I got the 30ff code.
Before that with the first two small pulls, I had no check engine light. I heard no sounds prior to this happening, no turbo whine, no smoke, nothing. |
08-18-2012, 12:40 PM | #6 |
Rep 457
Boost = pressure
You can't build pressure if there's a open hole in the system. If its big leak you wont build any boost. Smaller leak yes. Your boost leak is probably super obvious. Chargepipe connection or intercooler. |
08-18-2012, 02:13 PM | #8 |
GoofBall
50
Rep 1,055
If the wastegate isnt stuck open stopping the turbo from spooling, you have a huge leak somewhere in the system. It should show up like stated as something obvious in the charge side of the system.
08-18-2012, 02:21 PM | #9 |
Rep 1,054
check vac line..... have you moved, replaced any lately? Removed engine cover, brake boost line etc.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
08-18-2012, 02:36 PM | #10 | |
Rep 623
just my 2cents
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
08-18-2012, 10:45 PM | #12 |
Rep 2,590
Thanks for all the answers.
1.) Disconnected and reconnected IC, no tears or rips, clamped on very tight 2.) Replace vac hoses near oil filter housing, charge pipes and vac tanks 3.) Checked throttle body and charge pipe connections since I have meth also. 4.) Test rear wastegate for movement and it hinges freely without binding. Still no luck, I'm going to remove the tune tomorrow and see what happens. I also pulled the brake booster after a drive and didn't hear any whooshing sound. |
08-18-2012, 10:47 PM | #13 |
Rep 2,590
Nothing has been moved on this car since my meth install about 3 months ago. I did get a high pressure car wash (Yes I know they're bad for the paint) is there any chance something got knocked off with the undercarriage spray?
08-19-2012, 12:05 PM | #14 |
Rep 457
Doesn't matter if anything moved for months.
Thats extremely flawed logic. Your vacuum lines can crack over time and all the pipes on the positive side of the turbos are connected with o-rings and clamps. All of which fail over time. Randomly without warning or an event. |
08-19-2012, 06:07 PM | #15 | |
Rep 2,590
Also, tried uninstalling the procede and had the same issue with no boost. Now reinstalling the Proceded I have a 12000 code (2ee0, engine coolant temperature sensor), It won't stop running at full speed. This has been a terrible weekend for cars. Last edited by pits200; 08-19-2012 at 06:25 PM.. |
08-28-2012, 06:01 PM | #17 | |
Rep 2,799
thanks to MGallop |
08-29-2012, 04:58 AM | #18 |
Rep 2,590
08-31-2012, 10:40 AM | #19 |
Rep 2,590
Just updating all my threads to help if anyone runs into the same issues.
Problem found!!! My front actuator became disconnected from the wastegate and was just hanging there. I was essentially running on 1 turbo. I was able to get the actuator back on to the male end but don't have a clip to lock in place. Going forward, this is the checklist I would do if I had to troubleshoot again. 1.) Check CP and DV connections for leak 2.) Check vac lines for leak 3.) Check to see if actuators are connected to wastegates 3.) Leak test through intercooler 4.) Check if vac is building by driving car and pulling off brake booster and see if there is a swoosh 5.) Check wastegate movement with vac gauge to ensure movement and that the vac lines have no leaks 6.) Check boost solenoids (Even though I dont know how) |
08-31-2012, 11:42 AM | #21 | |
1750
Rep 17,960
Drives: A Lot
08-31-2012, 11:49 AM | #22 |
Rep 2,590
I was totally gonna give you some credit for that troubleshooting! 18 rep points for on phone diagnostics and I'll send you a Primanti sandwich when I send in my DME for a flash.
Thanks again for the help, sad thing is, part of me was sad to know that it wasn't a huge problem and that a single upgrade will have to wait. |
