FFTEC Turbo Kit #4
08-19-2012, 07:46 AM | #1 |
Big Boost Addict
52
Rep 689
Vishnu/FFTEC Turbo Kit #4
Will update as I get everything installed...
Finally a OPEN WASTEGATE car for everyone to enjoy the noises from lol... And my direct port meth manifold ready for installation... Hope you guys are ready for some real powaaaa! Come to Bimmerfest East this weekend if you want to see the kit in person...going on this car as soon as I get back from the 'fest... Last edited by jb's335; 08-21-2012 at 01:57 PM.. |
08-19-2012, 10:11 AM | #4 |
Rep 610
Looks bad ass, but are you worried at all about atomization or logging the IAT's as the meth is so close to the ports and won't be picked up by the sensor?
335i - stock for now
Escalade - Urban Assault Vehicle T/A - Forged ls1, PT8285 turbo, heads, cam, 4l80e w/Transbrake, s60 rear on e85. |
08-19-2012, 10:28 AM | #5 |
Rep 5,417
Insane car but I'm not sure I'm a fan of the direct port meth injection.
1. Too many connections for possible leaks 2. Prob going to get pretty hot there possibly boiling meth and introducing weak spots in the tubing and air bubbles 3. Proper automation and mix into the inlet air should be as far from the tb as possible to cool air efficiently 4. How are you sure you get the exact amount in every cylinder? 5. How will your tune adjust for cooler iat? |
08-19-2012, 10:32 AM | #6 |
442
Rep 18,331
How many pumps are you using for this direct port injection. Atomization will be compromised for sure as there are so many nozzles. Too large a nozzle you might experience quench, so tread carefully on choosing a nozzle size do to the reduce pressure of the pump from so many nozzles.
08-19-2012, 10:39 AM | #7 |
Sameet
740
Rep 2,541
Drives: AY/B M4 '15
Agreed with the above posters above meth being slightly compromised..but that is one badass looking manifold.
08-19-2012, 12:13 PM | #9 |
Rep 1,708
I think the direct port will be fine. Atomization is not as critical in this setup. Boiling meth is more of an issue pre-pump rathe rthan post. IATs for tuning would be a concern, but a small nozzle can be placed in the CP. Make sure you have the right nozzle sizes to keep psi up... 1500cc/min should be more than enough volume. Looking forward to the results.
08-19-2012, 01:40 PM | #10 | |
442
Rep 18,331
08-19-2012, 03:01 PM | #12 |
Rep 748
More pics of the kit? So this is a DIY kit?
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
08-19-2012, 03:07 PM | #13 |
Rep 2,396
Drives: '08 E90 335i
This is the Vishnu/FFTEC Single-Turbo kit, that IIRC can ONLY be installed by FFTEC (aka, you have to ship your car to them)
Here's the manufacturer's (Vishnu Tuning) listing for the kit: http://procedetuning.com/BMW/n54/styled-15/index.html |
08-19-2012, 03:43 PM | #14 | |
Rep 2,799
thanks to MGallop |
08-19-2012, 04:11 PM | #15 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
08-19-2012, 04:34 PM | #16 |
Rep 2,396
I stand corrected on all accounts
08-19-2012, 04:53 PM | #17 |
Rep 5,175
Quench has much more to do with the volume of water flow than anything else. I would be MUCH more concerned about boiling the meth or igniting any leak. I would not try what the OP is doing personally. We know my setup works beautifully at 650+ rwhp so why introduce such high risk or fire.
654 RWHP ... ! Vishnu/FFTEC Single Turbo 335
08-19-2012, 04:57 PM | #18 |
Rep 7,377
yeah that meth setup is quite scary... i would not run it...
08-19-2012, 05:09 PM | #19 |
Rep 462
How about using this for fuel e85 or just supplemental gas with actual injectors instead of nozzles according to shiv the v3 can control a second set of injectors
Irub |
08-19-2012, 07:28 PM | #21 | |
442
Rep 18,331
08-19-2012, 07:33 PM | #22 |
Rep 1,661
How are you able to get around the dme programming? I'm Really intersted in this kit but was planning on waiting til spring bc I thought I HAD to ship it over to Vishnu for the programming?!? Can someone explain what the dme reprogramming they have listed on their kit is for(I was initially told the reprogramming was for added fueling)...?
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
