Lag Bog Between Shifts
08-19-2012, 12:22 PM | #4 |
Rep 1,039
try shifting about 5800rpm and see if there is a difference. I have procede and sometimes have the same issue. typically when i shift a little earlier the bog issue is resolved, or at least goes unnoticed. I guess at the very least it cant hurt to try good luck getting this resolved.
08-19-2012, 12:30 PM | #6 |
Rep 1,039
08-19-2012, 01:51 PM | #8 | |
Rep 457
Stock with just tune beats m3 all day. Have you guys checked for vacuum leaks? I noticed a bog while shifting due to a cracked vacuum line that was feeding one of my wastegate actuators. I was still making full boost but it was slower spool (full boost at 3k not 1800-2k like normal. And it was bogging like shit between shifts. As if I was loosing ALL boost and having to spool from 0 like off the line. It was creating this 3-4 second lag like I didn't even push the gas. Almost like the restriction of Not having downpipes. The turbos inertia when shifting from 2-3-4-5-6th should allow for instant boost after shifts. Alternatively via the jb4 interface (laptop) You can also turn off the bogfix and adjust the lagfix value lower or higher to see if this helps. |
08-19-2012, 04:47 PM | #9 |
Rep 2,291
I think this is driver dependent. A friend of mine has this problem with his car, but I cannot reproduce the issue when I'm driving it. The differences in driving styles that I can see is that he "dumps" the clutch with full travel with each gear change. By contract, my gear changes only involve about an inch of travel.
08-19-2012, 05:00 PM | #10 |
adrenergic stimulation
Rep 405
I agree with the squirrel. When I dump the clutch hard inbetween shifts I get the bog. Other times when I don't fully put the clutch to the floor and work it out slower than a full dump I can have a great shift without bog. The fact that I can experience both bog and no bog shifts leads me to believe that it depends on how you work the clutch.
08-19-2012, 05:35 PM | #12 | |
Rep 2,704
Shift at a lower rpm used tonhelp my car, also just keeping the gas down the whole time did the trick as well, but puts more stress on the tranny. |
08-20-2012, 05:39 PM | #15 |
Rep 2,704
08-20-2012, 05:57 PM | #16 |
Rep 457
08-20-2012, 05:59 PM | #17 |
3442
Rep 79,211
Either send logs to BMS to try to fix it, or you may want to try another tune. Sometimes you just cant avoid the bog on some tunes.
To whoever said they all do it, I'd have to disagree, PROcede didn't bog on me and I wasn't running NLS. |
08-20-2012, 06:04 PM | #18 |
Rep 290
latest firmware i did notice this as well i adjusted the bogfix from 100 to 80 and on my car felt fine after that..
2008 135i 6-speed current stock for now
1995 e36 M3 5-speed Jb4 G5//CM-FX400//FBO//Meth// 12.06@118 6-speed manual sold summer 2013 |
08-20-2012, 06:37 PM | #20 | |
Rep 932
It's just a function of the dme as stated earlier, even stock bogs. And how does driver error cause this? Didn't realize shifting fast was bad lol |
08-20-2012, 06:38 PM | #21 | |
3442
Rep 79,211
If people are tired of bogging they should try a new car if its inherently stuck in the DME |
08-20-2012, 06:40 PM | #22 |
1750
Rep 17,960
Drives: A Lot
With the Procede, the only time i've seen bogs is when the revs hit the rev limiter during the clutch-in period. This can happen due to the lag between the actual throttle pedal lift and the throttle closure. Or if the driver stays too long on the throttle once the clutch goes in. And once the rev limiter is active, the throttle blade tends to have a mind of its own. Using the NLS relay to trigger an aux rev limit 100rpm below the DME redline is a good solution to this issue. In fact, it's what got my ETs down from 11.0-11.2 to 10.8s. The 1-2 shift, at 25psi of boost, was killing me.
Shiv |
