Procede v2.5 slight hiccup at 1.0psi
08-20-2012, 09:08 AM | #1 |
Power without control is no power at all...
15
Rep 190
Hi guys, I've been running Procede v2.5 for a few days now and I keep getting a slight hesitation ~2k rpm. I thought it was the 7_29 autotune map that was doing it so I switched to Stage 1 5_23 aggressive map, but still have the issue. I have a Rixter gauge and I noticed that it happens right around 1.0-1.5psi; once the boost reach 1.0-1.5psi it immediately drops to 0.0psi and begins building again, so it's like a slight hesitation. It's the only time I have any issues and it only happens in 1st or 2nd gear. Diverter valves or vacuum lines?
Procede v2.5 and DCI
2009 335i Coupe 6MT Blk Sapphire / Blk Leather
2007 328i Coupe 6MT Blk Sapphire / Blk Leather *Sold 1985 Toyota Corolla GTS 5MT 1.5-way Slvr / Blk *Sold 1987 Toyota Corolla GTS 5MT KAAZ 2-way Blk / Blk *Sold |
08-20-2012, 10:49 AM | #2 | |
Rep 2,291
If you spark plugs need changing, you should go ahead and change them. Its possible that will resolve your problem. |
08-20-2012, 07:58 PM | #3 |
15
Rep 190
I'll check the plugs out, but they were replaced at 45k so I doubt it's them. I also had the LPFP sensor and HPFP replaced at 49k. I'd hate to replace the coils and injectors if they're not the problem. I'll see what the plugs show me.
08-22-2012, 10:11 PM | #4 |
15
Rep 190
I changed my oil and pulled my plugs - everything looked fine. I don't have any misfires or anything under full load (WOT going up a steep hill) and boost is steady everywhere except ~1.0 psi, so I'm thinking I might need a walnut blasting since I'm at 54k and counting. Probably going to order the gear later this week.
08-22-2012, 10:19 PM | #5 | |
1750
Rep 17,960
Drives: A Lot
08-22-2012, 10:39 PM | #6 |
15
Rep 190
I pulled the plugs - they looked fine as expected since they were changed ~9k ago - and I put them back in.
Side note: I've been stalling out (car just dies out softly) about once every two days - do you think this is related to carbon buildup? I have very good clutch modulation and never give too much gas - almost as smooth as an automatic. I think the Procede is magnifying whatever hardware problem there is.
08-22-2012, 11:34 PM | #7 | |
1750
Rep 17,960
Drives: A Lot
08-25-2012, 02:53 PM | #9 |
15
Rep 190
Not resolved . . . yet. I've just ordered the tools for the walnut blasting so we'll see how the car responds to that. Probably a labor day weekend project.
http://www.n54tech.com/forums/showthread.php?t=16734
