What is up with all the DME Failure talk?
08-24-2012, 09:01 PM | #1 |
Rep 942
Guys, am I late to the party or something? I've been seeing some crazy threads about DME failures. Some say it's for a few months of '07's, other say some 10's... can someone get me up to speed on this issue? What does the TSB look like? I'd like to know if my car is on the crap list. And more importantly if I am, how to get the dealer to fix it, and do I have to remove my procede?
'07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, Macht Schnell Downpipes, 18" Staggered 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Dinan Oil Cooler, Dinan Intercooler, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Blend V1 mount, Llumar ATR Tint.
08-24-2012, 09:07 PM | #2 | |
Rep 194
08-24-2012, 10:10 PM | #3 |
Rep 942
Believe it's a late '07. Are they actually replacing the ECU or just re-flashing it?
08-24-2012, 10:15 PM | #4 | |
Rep 194
08-24-2012, 11:46 PM | #6 |
Rep 942
F! I need to check my build date. thanks guys.
08-24-2012, 11:51 PM | #7 | |
Rep 2,556
Sure hope not. Are there any warning signs?
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
08-25-2012, 08:32 AM | #9 |
Rep 194
Everything I read about the dme going out had the same symptoms. Hitting full boost at around 6200rpm and then the car just starts shaking violently in some cases and continues even after restarting and changing of plugs and coils.
08-25-2012, 08:43 AM | #10 |
442
Rep 18,331
It hits full boost and the loud bang and car stumbles because the injectors shut off and no longer running on all cylinders. The defective diodes I think control the fuel injectors. Mine is a 3/07 build and it's too close for comfort still
08-25-2012, 04:21 PM | #12 |
Rep 942
Bad news for me... Build date of 07/07. Good news is I'm still under my CPO warranty until Aug 31, 2013. Now for the question.... I'm guessing I have to remove my Procede tuner (what a waste of time!) and see if they will do it before the thing blows up. Any help getting this done? Anyone have the link or PDF of the bulletin?
08-25-2012, 08:00 PM | #13 |
Rep 968
Drives: 2007 335i Coupe
Mine is a 06/06 built e92 and had a failure. Injector adaptor failed
08-25-2012, 08:52 PM | #14 |
Rep 2,602
I have a 3/07 build and a diode failed, dme crapped right out. My car was fbo, they didnt say a word, started a puma case and changed the dme.
08-25-2012, 09:00 PM | #15 |
Rep 942
^ I don't have that kind of luck in life.
08-25-2012, 10:51 PM | #16 | |
Rep 53
When my car started up, it would rev from 1k-2k up and down itself continuously, very odd..... Anyways after reading this thread I think I may ask/get injectors now (CPO warranty) |
08-26-2012, 10:17 AM | #17 |
Rep 194
Ask the dealer if they can do a carbon cleaning for you. Sounds like your valves need to be clean since you're still under warranty. Reason why your rpm keeps revving up and down by itself.
08-26-2012, 02:41 PM | #18 |
Rep 942
^ guys, if the DME doesn't fail, and I get it replaced, the injectors should be fine right? I think everyone is getting injectors replaced once it fails it takes some injectors out with it electronically, correct?
08-27-2012, 07:59 AM | #19 | |
Black on Black on Black.
38
Rep 532
LEMANS BLUE M-TECH E92->PROCEDE REV3::BIEHNTUNE FLASH::ETS 7" FMIC::RACELAND DPS::OS GIKEN 1.5 WAY::DEFIV DIFF LOCKDOWN::DEFIV OCC::DEFIV INTAKE::RB PCV |
08-27-2012, 09:08 AM | #20 |
Rep 942
Again, does anyone have the official paper work from BMW on this issue so I can print and take it with me to the dealer?
08-27-2012, 05:36 PM | #21 |
Rep 53
08-27-2012, 06:17 PM | #22 |
Rep 942
that's the problem. You need a procede so you can properly reset the deals.
