Some friendly Log review :)
08-28-2012, 08:29 PM | #1 |
Rep 1,039
So What do you all think??? 1st log is map 1, and 2nd log is map 4 with meth 70/30
The car has DCI, catless dp on 93oct. 5-23 stage 2 aggressive. Map 1 Map 4 Meth 70/30 mix. See the deviation in the fuel trims with meth flowing? Last edited by Bme30; 08-28-2012 at 08:49 PM.. |
08-28-2012, 09:00 PM | #2 |
Rep 5,417
With meth obviously looks 10 times better. The first log your timing is pulled probably because of the lack of good octane and high intake temps. I'd like to see what your boost targets look like
08-28-2012, 09:04 PM | #3 |
Rep 1,039
So the separation in the fuel trims isnt detrimental? I should have done some boost targets, but didn't. I will make sure to logs those on my next logs!
08-29-2012, 05:58 AM | #5 |
Rep 1,039
I was under the impression that I may have o2 sensor(s) on the way out?
Why would they be together without meth flowing and than separated while meth is flowing. |
08-29-2012, 08:09 AM | #6 |
Rep 923
It could either be uneven Meth distribution between the 2 Banks, or your injectors are having a hard time keeping up. There was a little separation between the 2 Banks on Map 1 as well, but it may be exaggerated by the additional boost while running Map 4.
08-29-2012, 08:13 AM | #7 | |
Rep 2,842
The reasoning is that the meth is not being evenly distributed between banks due to lack of time to atomize evenly. Some have reported improvements to trims by relocating the nozzles further upstream, thus giving the mixture more time to homogenize. If your trims are fine when NOT flowing meth, then I wouldn't worry about the O2 sensor being the culprit here. Which meth kit are you using.....Vishnu PWM? |
08-29-2012, 08:15 AM | #8 | ||
Rep 1,039
08-29-2012, 08:19 AM | #9 |
Rep 1,039
I have also never had the injectors replaced.....was hoping I wouldn't need too. I only have 39k on my 2007.
08-29-2012, 09:29 AM | #11 |
Rep 473
Everythig looks decently on par to me I have a HFS-4 kit on my car and but a Vishnu charge pipe and the difference between my fuel trims looks similar although they could be closer together I see a variance between 4% and -12. Also Vishnus charge pipe has the meth nozzles placed in a pretty optimal spot.
Cobb JR Tune, HFS-4, DCI, AMS Intercooler, Vishnu CP, Forge DV's, AR DP's, RPI exhaust, AR OCC, BMW STS, Spec stage 3+ clutch, CDV delete, H&R Coil overs, Quaife LSD, DefiV Lock down kit, WOTbox.
-SOLD Last edited by 3-Serious; 08-29-2012 at 09:35 AM.. |
08-29-2012, 09:40 AM | #12 |
Chump
10
Rep 173
Looks good, I'm jealous, wish my logs ever looked that good.
Shiv said in another post a few days ago that it is typical to see a delta of +/- 10 on the fuel trim banks with meth injection and that there is no real detrimental effect. Yours look on par with that assertion. Now just throw in some e85 and that map 1 log will look better!
2009 e90 LCI Blacked Out Space Gray - Vishnu Procede 2.5 w/9-10 Aggressive Map Stg2 - PWM Meth (80%) - BMS DCI - VRSF Intercooler - VRSF Downpipes - HKS Cat-back Exhaust
08-29-2012, 12:31 PM | #13 | |
Rep 1,039
I only make 331/385 with dci, catless dp and no meth. I was really hoping for the 350 range like so many others. I make 389/440 with meth flowing. |
08-29-2012, 03:16 PM | #14 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
I am a log-reading newb. What represents timing pulls on the graph? is that those fluctuations around peak rpm in the CAN ignition adv curve?
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
08-29-2012, 03:24 PM | #15 | |
Rep 5,417
08-29-2012, 06:00 PM | #16 | |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
08-29-2012, 09:00 PM | #17 | |
Rep 1,039
I also have been following your posts a little and am very envious of the power you are making. |
08-29-2012, 09:22 PM | #18 | |
Rep 6,771
Drives: 2016 BMW i8
I found that I liked the violent rush of going from 13psi to around 18 to 18.5 psi instantly at 4,500 rpm and then tapering gradually down to 16psi. I found that it was also good for off-the-line traction as I could just put the auto tranny in 2nd gear and launch with no wheel spin whatsoever with this profile. On the dyno, torque using this boost profile was a bit lower from 3,000 to 4,300 as compared with the stock map settings from Vishnu at 65 start boost, but once I hit 4,500 rpm boost would spike to 18-18.5 and hold for long enough to provide for a nice power increase up to peak power at around 5,500 RPM, then the taper to redline was same as with the stock 65 start boost settings. You can see my boost, torque and HP curves for my stock boost, standard 65 start boost, and custom boost profile which probably explains it pictorally much better than I just tried to explain > see post 203 > http://www.e90post.com/forums/showth...416797&page=10
08-29-2012, 09:23 PM | #19 | |
Reborn
87
Rep 1,217
08-29-2012, 09:28 PM | #20 |
Rep 6,771
Drives: 2016 BMW i8
Actually that's just the post shift timing drop for the 6ATs. Most of us have them no matter if you are running 8psi or 18psi.
08-29-2012, 09:32 PM | #21 |
Rep 1,039
08-29-2012, 09:34 PM | #22 |
Rep 1,039
I'm a 6mt. But I might take you up on that offer when I get this car running perfectly. Although zero codes or hiccups when pushing it!
