F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Will E46 M3 rims fit?
proTUNING Freaks
      09-27-2012, 11:22 AM   #1
DR.Nefario
DR.Nefario's Avatar
86
Drives: 2013 Dakar Yellow M3
I have my ZCP rims from my E46 M3 and just wanted to know if they would fit my F30 328i with H&R super sport springs. The sizes are 19" x 9.5" with a 27mm offset for the rear and 19" x 8" for the front with a 47mm offset. Thanks
      09-27-2012, 12:06 PM   #2
jose_sonictuning
jose_sonictuning's Avatar
Drives: BMW F30
Your front is fine, might need spacer.
Rear is aggressive for the F30, you can pull it off by running stretch tires and some negative camber. I would suggest 255/30-19 in the rear.
      09-27-2012, 12:09 PM   #3
martinf79
martinf79's Avatar
192
Drives: 2020 G05 X5 M50i
I would say... absolutely not. I am putting ZCP relica's on for the winter.
My rears are 9.5" w/ +38 offset, and they are 9mm out from stock (which is essentially flush w/ the fender). Your rims would stick out another 11mm (so 20mm vs. stock setup). Will look really bad and will for sure hit the fender.
Fronts - I am going w/ a 8.5" w/ +35. Stock is 8" w/ +35 offset, so you are going to be really far inward (+12mm) and would suspect that you might hit a number of components on the inner wheel well).
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      09-27-2012, 12:09 PM   #4
martinf79
martinf79's Avatar
192
As I always say ... use this tool:
http://www.rimsntires.com/specs.jsp
      09-27-2012, 12:23 PM   #5
DR.Nefario
DR.Nefario's Avatar
86
Thanks for confirming what I already thought. I guess I'll sell them and go with a different set-up
f30post
