E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Oil in Charge Pipe
Reply
      09-28-2012, 08:29 PM   #1
335jacket
Drives: 2007 e92 335i
Oil in Charge Pipe
Hey Guys.
I'm pretty new to the forums, but I've been reading posts for months. I have tried to search for this one, but I can't find an answer....
I have a e92 n54 with 60k and I bought it with a few aftermarket parts, aFe DCI and a coated aluminum charge pipe with an HKS BOV. I decided to take the charge pipe off and check out carbon build up on the TB. My plan was to clean the TB and MAF and just generally check it out.
I removed the air intake and the charge pipe and noticed a few drops of oil coming from the TB. I looked inside the charge pipe and saw that there was some oil collected at the bottom of it. Can anyone explain why there would be engine oil there? Is this an indication of problems with the turbos?
      09-29-2012, 09:09 AM   #2
kfrazie1
kfrazie1's Avatar
64
Drives: 335i
Probably blow by from the pcv system. Most people have the same issue and usually get a catch can.
Montego Blue E90 335i
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP
      09-29-2012, 01:52 PM   #3
335jacket
Got it. Catch can it is...
Thanks man.
      09-30-2012, 12:29 PM   #4
e679
e679's Avatar
Hong Kong
9
Drives: E93
Originally Posted by 335jacket View Post
Hey Guys.
I have this problem too. My car is stock and with 20K miles. Did your turbo run normal? May I ask what oil are you running? Thanks.
E93 335i Alpine White, 19" Works, PSS, M3 arms, M3 bushings,M3 E93 FSB/E92 RSB, powerflex rear diff bush.
AST 5100 with M3 rear camber arms. GC street plates.
      09-30-2012, 07:40 PM   #5
335jacket
I'm pretty sure my turbos run fine. I run the stock 10w-40 Castrol...
Reply
Tags
intake oil
e90post
