CMGS 1.10 help
10-03-2012, 05:07 PM | #1 |
Rep 788
I have manually learned system and its been working fine all this time. Took it to track and after two laps no more flow. I restated car and worked again but no flow reoccurred once back on track. 004 fault code.
All first 8 lights are lit upon CMGS start up. That means its learned. I tried to manually learn system again. DC 30 to 100 are fine. DC 10 and 20 do not flash while trying to learn. I have left it run for minutes...... I have very low flow on these so system doesn't learn anymore I guess. Flow was stronger on these lower DC in past. Should I change param 9 ?? It's at default now (20). Or maybe param 10 needs changing?? It's at 13 now. I keep getting 004 fault. Pump problem at low duty.....
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design |
10-04-2012, 06:59 PM | #2 |
Rep 788
Anyone?
