cobb stage 2+ agreesive 30FF
10-09-2012, 05:05 PM | #1 |
Rep 88
I have a 335i fbo with cobb stage 2 agreessive +, and gear changes over 6000rpm, I get the fault code 30ff.
The leak must be very small because I only appears in those change gearshifts at full throttle. The pipes look good, it can be? thanks |
10-09-2012, 05:11 PM | #2 |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
10-09-2012, 05:17 PM | #3 |
Rep 2,626
+1
btw do you only get the code in higher gears (say 3rd) at high rpms?
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
10-09-2012, 05:23 PM | #4 |
Rep 88
10-09-2012, 05:27 PM | #5 |
Rep 2,626
so if you run in 3rd gear say from 3000rpm to 7000 would you get the code? just trying to compare to my case.
my car was having issues holding boost at high rpms. After 5000 rpms, boost delta from requested starts increasing. I would trigger a code in 3rd or 4th... since the DME has time to figure out something is wrong.
10-09-2012, 05:27 PM | #6 |
Rep 623
I have a buddy thats getting the exact same thing... Only at higher gear changes 3rd and 4th above 6k... trying to get it sorted out and got boost leak done and none??? Sort of in between a rock and a hard place....
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
10-09-2012, 05:31 PM | #7 | |
Rep 2,626
I would first swap boost solenoids with another N54 that has no issues hitting boost targets. they were the culprit on my car.
10-09-2012, 05:31 PM | #8 |
Rep 88
the failure warning appears exactly at the time of release the clutch, the gear is up, is the instantaneous appearance of the code,
if accelerated to 2000rpm to 6500rpm fund since sometimes do not see the code and other are. |
10-09-2012, 05:33 PM | #9 | |
Rep 88
10-09-2012, 05:36 PM | #10 |
Rep 2,626
Do you have any logs? may be there is a sign of a boost leak even though your symptoms don't indicate a boost leak.
Do you hit boost target throughout the range? Log requested vs actual and WGDC on banks...
10-09-2012, 05:52 PM | #12 |
Rep 2,626
It's a long log. Is this a third, part of 4th and then just cruising around.
around what time stamp did you get the limp you're saying?
10-09-2012, 05:54 PM | #13 |
Rep 2,626
I take it back, it seems it is multiple pulls in one log.
10-09-2012, 06:03 PM | #15 |
Rep 2,626
well you are deviating from boost target obviously. It is similar to what I was getting in the sense that it gets worse at higher rpms. You off target by more than 2psi in some instances at high rpms. my car was off by 3-4 psi at one point...
In my case the solenoids solved the issue.
10-09-2012, 09:01 PM | #16 |
OEM+ is the shit
34
Rep 543
Had the exact same problem as you after a few weeks with Cobb st2+. I solved it with upgraded DV's and chargepipe.
M-Tech - MFD - 9/10,5x18" BBS E28 - H&R - COBB - Supersprint - BMS - BigTom IC - Ultimate Racing www.Youtube.com/user/CarleeSWE www.Garaget.org/Carlee82 |
10-10-2012, 10:16 AM | #18 | |
Rep 2,626
You are right worst i've seen is 1.3psi, which is completely OK. Should not even give you underboost. did you get a limp this time??
