5E19 and 2D58 codes after DME flexfuel reflash
10-12-2012, 02:19 AM | #1 |
Rep 71
Just receive my flex kit and my dme reflash by Vishnu, after a long period...
I post here since i can't have any answer from vishnu, i waited for two weeks without car and now i can't use it.If you read this post you're probably a Vishnu fan so am i, products are great but after market service isn't that great. The car is unusable now don't stop to receive various codes. The most annoying ones are 2D58 and 5E19. The first, 2D58, don't stop to pop with the traditional 30FF, 3100 codes just after. It comes in 3, 4,5 and 6th gear after 4000rpm, it's not very worried because i can drive the car to stop it, check code, clear it and drive again. The 5E19 code is the real problem, it's a DSC malfunction. It appears with or without the DSC activation at random rpm and when it pop i loose every car's controls, no throttle at all. When i succeed to stop it idle vary brutally between 1000 and 1500 rpm in a second or two like wave in an oscilloscope. This never appends before the dme reflash. When i have the chance a have a clear pull performance are far better tan before with 50/50mix but in 100kms i receive those codes at least 20 times each. The question is to know if it has a correlation with the dme reflash or is it because the tune is more aggressive and every thing else. Please be gentle with my english and with me, i desesperate to have answers from vishnu and this situation is dangerous when i receive the codes. Thanks. Last edited by pinto; 10-12-2012 at 02:59 AM.. |
10-12-2012, 02:34 AM | #2 |
1750
Rep 17,960
Drives: A Lot
I just checked the sales@vishnutuning.com email and i'm afraid the office was already closed when your emails arrived in the inbox. I sent you an email with some info I need to troubleshoot. Just reply to shiv@vishnutuning.com and I can help directly. It's a bit past midnight here but i'll be up a little bit longer.
10-12-2012, 09:48 AM | #6 |
Rep 7,377
I hope you dont need to send it back again...
