10-12-2012, 03:14 PM | #1 |
Rep 51
low oil
Low oil light came on and took it to dealer and they had to add a quart. I'm at 8k miles. I said isn't it alarming that oil level is low on a new car? The service guy said "have you owned a bmw before??" I said no but generally with any car you don't lose oil right? He said it's not abnormal to have to top off between service.
What's the deal? do all you guys have oil hanging out in the garage? is he full of it? |
10-12-2012, 03:36 PM | #2 |
Yup
105
Rep 699
Same thing happened to me, 13k miles
Went to service , quick and easy Very typical of turbo engines to burn oil
Oh hello
10-12-2012, 03:43 PM | #3 |
Rep 312
Had the exact same conversation with my dealer last week (10K). Apparently completely normal. All internal combustion engines consume some oil, albeit not much (unless there is a problem). Replacing every 3,000 miles keeps this from becoming an issue. It all boils down to the interval between oil changes that makes this small consumption apparent. The high performance M cars will burn about 1 quart every 4,000 miles. For our car, I heard every 8 - 10K is the average per quart.
10-12-2012, 04:05 PM | #4 |
Rep 51
thanks for verifying. I guess there should be lots of us hitting 8-10k miles now. I'm wondering if all of the 335ers are running to get oil.
that's pretty inconvenient to have to bring the car in for oil and then not too long later again for service. |
10-12-2012, 04:17 PM | #5 |
Rep 69
I'd say it's more a function of the extended service intervals. Sure, every engine consumes oil...just shouldn't be over a short interval. Personally, my old Saab turbos never used a drop - being down a quart at 8k is significant, keep an eye on it.
10-12-2012, 06:12 PM | #8 |
Rep 3,870
My car alerted me at 6000, asking for topping off because it was getting close to the minimum oil level...
so i took the car in at around 6000 miles, then again at 9000 miles is my 335i that thirsty for oil ?? My First service is due in 3ooo miles to so, perfect timing for changing the oil and topping it off with fresh ones.
10-12-2012, 09:16 PM | #10 |
Rep 2,148
Drives: F87 M2 BSM MT
All turbo cars burn oil!! This is my first BMW but not my first car with a turbo so I know its normal. It actually took longer than expected mine came on around 7000miles. process was quick and easy.
I drove straight to the service area and told the guy standing out there he goes to a cabinet they have setup outside grab a quart fill it and run engine check from idrive. no paper work or exchange of names or anything. process was under 10mins.
10-12-2012, 11:35 PM | #11 |
Rep 108
I have a 1L bottle of oil in the back under the trunk plate. It came with the car and was explained during delivery as an emergency stash.
It is next to the case of lights. |
11-22-2013, 02:41 PM | #13 |
Rep 2
Drives: 2012 335i
Yep, the process was simple for me and my 335i. As others have said, it's normal for a turbo. For me it happened in the first few thousand miles
11-22-2013, 03:17 PM | #14 |
Rep 2,266
I used my own oil. But does our maintenance include topping off the oil? Thought I read BMW isn't doing that anymore.
F30 Sapphire Black M-Sport 335i 6MT
