Stage 2+ blown chargepipe first pull. How?
10-23-2012, 12:41 PM | #1 |
Rep 1,153
Yesterday I went out to log for the first time since installing my Mr. 5 intake, VRSF 7" fmic & downpipes. As I roll into boost on my very first pull around 4K rpms I heard a popping sound and the car lost power. It took a minute before a code came up but eventually I saw a P30FF boost leak. The charge pipe blew off right at the clamp and broke. I haven't seen a stock charge pipe yet but is there supposed to be a metal ring or something that locks it in place to the throttle body? I can't seem to find any pieces to it and don't think they could have made their way into the intake. They are probably in the undertray somewhere.
In the second pic you can see the Mr 5 intake I bought. I'm surprised the flange blew off the intake box as it's not pressurized and it didn't happen between shifts. I'm just going to silicone it back on and bolt it.
2016 340i xdrive
2009 335i |
10-23-2012, 12:42 PM | #2 |
Rep 7,377
Well hehe increased boost and bad mechanic skills
Actually thats the stock cp? U are not the first one to destroy it. Just buy a good one
10-23-2012, 12:47 PM | #3 |
Rep 439
thats some bad luck right there.....my first pull when i did my charge pipe blew it off and disconnected the sensor back there and it took my about 3 hours to figure out the problem lol
2011 335is "Redrkt" 6 MT
DocRace 6266 Single Turbo - Fuel it stage 3 LPFP - Fuel it PI - spec stage 3+ clutch - mfactory SM flywheel - 100% E85 - VRSF 7.5" intercooler - VRSF charge pipe w/ HKS BOV - JB4 - MHD back end flash 768 whp 695 ft lbs - E85 - 32PSI |
10-23-2012, 12:50 PM | #4 |
Rep 2,626
Time to upgrade to an aftermarket CP
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
10-23-2012, 12:58 PM | #6 | |
Rep 1,153
Bad mechanic skills? I guess you are talking about whomever made the intake? I'm thinking about picking up a CP where I can run the stock DV's until i need to upgrade to Forge or AWE.
2016 340i xdrive
2009 335i |
10-23-2012, 01:06 PM | #7 |
Rep 7,377
see my edit... you destroyed stock cp... just buy a good one and blaim bmw for not supporting 18 psi....
10-23-2012, 03:01 PM | #8 |
3442
Rep 79,211
I dont get why the intake did that either, maybe it was simply coincidental. However, I recommend the Evolution Racewerks Charge pipe. We got a handful in stock ready to ship to get back on the road. Hit me up.
The stock CP has a metal C clip. It likely fell into the black hole of that engine bay. I doubt it got sucked up that would be quite the feat. |
10-23-2012, 03:36 PM | #10 |
Rep 6,136
What year is your car out of curiosity? Reason I ask is because I feel like when these threads come up, it almost always happens to the cars 09+ with the redesigned CP
10-23-2012, 03:51 PM | #11 |
Rep 232
im running stock cp @ 19 psi with no problem
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
10-23-2012, 03:51 PM | #12 |
Rep 1,903
Drives: e92 335i 6MT
Stock cp and dv here, pushing 19+psi and no issues
10-23-2012, 03:53 PM | #13 |
Rep 1,054
Damn. Seems like a very common problem. I wonder if I broke my charge pipe too. Will have to check in the morning.
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler http://www.e90post.com/forums/showthread.php?t=782212 |
10-23-2012, 03:56 PM | #14 |
Rep 7,377
yeah if that would be a big problem...
10-23-2012, 03:57 PM | #15 |
Rep 3,157
As far as the charge pipe is concerned its bound to happen sooner or later... Time for a Active Charge pipe and Bov
The filter box.. I have no clue how you managed that one |
10-23-2012, 04:07 PM | #16 |
Rep 2,898
10-23-2012, 04:20 PM | #17 | |
Rep 10,587
I saw your car over at Adam's, lookin real good! Bet its a blast to drive too.
10-23-2012, 04:29 PM | #18 | |||
Rep 1,153
From looking at the intake, the flange just popped off. It had some sort of a plastic glue holding it on. I have to bolt it on with some silicone. I am worried about the O-ring I hear of. I can't find that either and imagine it's possible that it could get sucked in. It's probably just paranoia.
2016 340i xdrive
2009 335i |
10-23-2012, 04:35 PM | #19 |
Rep 6,136
10-23-2012, 04:40 PM | #20 |
Rep 2,387
I don't understand how the intake blew up like that, did it happen at the same time as the CP? Are you running meth or something? I would think some kind of backfire thru the intake tract but that makes no sense given the piping arrangement and location of IC/turbos.
