help: just removed my second catts with straight pipes and sounds terible!
10-25-2012, 06:45 AM | #1 |
ZEE DEE
15
Rep 62
hi guies, i just removed my second catts and sounds so bad, like really rattle tinny vibration sound, comming out of the back of the car (extreamly loud), i have, rr cattless downpipes, the rattle sound starts from 1.8k rpm till about 2.1k rmp when the car is under slight load. it sounds terrible!!!(it sounds like the muffler baffles are vibrating). i have jacked the car up and had a look, however i dont see anything rubbing on the exaust. the sound is so bad literally sounds like a honda civic with hole in exaust. the only time it sounds better is when i use DS mode as the car keeps the revs above 2k normally. i have tried golf tee mod and without. sounds a bit worse with the golf tee mod. please any help would be greatly appreciated! thank you!
10-25-2012, 06:46 AM | #2 |
ZEE DEE
15
Rep 62
i also got bigger exaust tips welded on at the same time i got the second catts removed. definatly not the sound i was trying to achive from some of the circulating youtube vids.
10-25-2012, 06:49 AM | #3 |
JB4, BMS intake
17
Rep 244
Drives: White BMW 335xi Coupe
10-25-2012, 07:23 AM | #4 |
Rep 7,377
you should have searched/asked before doing that. Especially with AT fully catless without any resonators it sounds like crap....
10-25-2012, 07:32 AM | #5 |
442
Rep 18,331
10-25-2012, 08:31 AM | #7 |
Rep 4,633
I am fully catless and no resonator.. stock mufflers. No strange sounds.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
10-25-2012, 09:55 AM | #9 |
Rep 4,633
10-25-2012, 10:06 AM | #10 |
Rep 3,262
You need to weld Vibrant 1792 resonators instead of the cats, otherwise the sound is unbearably raspy. However once you put the resonators in, everything will come back to normal.
10-25-2012, 02:41 PM | #11 |
ZEE DEE
15
Rep 62
thanx guies! the sound it terible sounds like the exaust is touching something. i think im just going to put the catts back in as the car does small a bit. i did notice a peformance imrovement removing the rear catts!! definatly! maby i drill a couple of holes in this one b4 putting it back in hahahah. dam n54 is running at its limit, wish there was a fuel upgrade so i could mount some massive turbos. so i dont have to do stupid things like remove my catts in a desperate move just to make more power. haha
