10-25-2012, 08:02 AM | #1 |
Rep 137
H&R Sport Springs Question
Hi all, I have a question for those that have put H&R sport springs on their F30 335i. Has anyone with this setup driven around with 4 passengers in the car and if so have you experienced any rubbing? I should specify that I have a sport line model with the stock 18's and don't plan on changing the rim/tire setup. Again, I'm looking at putting on the Sport Spring, not Super Sport. I'm new to putting springs on a car so not sure if I'd need anything else other than the H&R springs or if those are all I'd need to install. I've done some research but couldn't find any info on this. If anyone can give some feedback from experience on this it would be great. Thanks.
10-25-2012, 08:52 PM | #4 |
Rep 3,307
10-25-2012, 09:06 PM | #5 |
Rep 664
Drives: 2013 BMW 335i
from the looks of it there shouldnt be any rubbing. take a look at this post http://www.f30post.com/forums/showthread.php?t=757168 it's also a sport line on H&R Sport springs...
Im wondering about the H&R Super Sport with the stock 18" sport rims. I want the gap smaller. but afraid it might be too low to the ground with 18s... |
10-31-2012, 03:55 PM | #6 |
Rep 1,245
I can vouche for the HR sport not rubbing with a full cabin, thats with the staggered Msport 18s
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i |
11-01-2012, 09:42 AM | #9 |
BMW 4 Life...
149
Rep 3,360
I've got a more agressive setup with H&R Sport Springs.
With four people there is no rubbing. However, I am very careful on speed bumps to make sure I dont hit the fender. All in all, I'm very happy with everything and the quality of the ride.
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
11-01-2012, 10:46 AM | #10 |
Rep 4,323
you guys didn't change your shocks/struts when adding the springs?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
11-01-2012, 11:40 AM | #11 |
101
Rep 1,237
11-01-2012, 12:17 PM | #12 |
Rep 1,975
11-01-2012, 12:19 PM | #13 |
101
Rep 1,237
Actually... it depends. If you have a 328i, the ride shouldn't suck too badly. But if you have a 335i, it will kinda suck. It's not unbearable. But I don't agree with some people's opinion that "it should've come from the factory like this" or "it rides just like stock!", because it doesn't.
11-01-2012, 01:19 PM | #14 | |
Rep 1,975
11-01-2012, 06:03 PM | #16 |
Rep 1,245
no complaints on ride quality...it's better compared to my E90 with BMW perf. suspension anyways...the EDC probably plays a big part in that though
...granted it doesn't feel as planted as my E90 did
11-01-2012, 09:48 PM | #17 |
Rep 4,323
You guys are freaking me out.
I'm considering the M Perf Suspension as an alternative...the base model has a real floaty suspension...
11-02-2012, 02:03 AM | #18 | |
101
Rep 1,237
The H&Rs are NOT bad springs at all. It's just the combination of the H&Rs and stock struts that ruin the balance of everything. The stock struts just aren't calibrated for the stiffness and height of the H&Rs so it just bounces around on every bump and groove in the road. When a good set of matching struts become available, that combo would be the way to go. Again, on the 328i, the springs will feel much nicer than on a 335i. If you look at all the pics of F30s (in the USA) lowered on H&Rs, the 328s are way higher than the 335s due to the smaller/lighter engine. This will allow more shock travel so that the strut can actually do it's job.... well, at least part of it since there is still a compromise. With the H&Rs on a 335i, you barely get any shock travel room. So it inherently becomes "bouncy" and you bottom out a lot faster. The bounce wasn't too bad for me at first. It's definitely bearable. But it eventually got to me like Chinese Water Torture. Eventually, the repetitive consistent bounce drove me crazy. It came to a head when I was driving on the freeway in the fast lane one night. I could see my xenon headlight cut-off very clearly on the concrete median. It was comical and embarrassing how bouncy the car was. It literally looked like all the honda owners in the 90s that just cut their springs (I know because I was one of those). |
11-02-2012, 09:27 AM | #19 | |
Rep 4,323
H&R might be too aggressive for me since the car is my DD, I don't want it to be as bad as my Evo VIII was...towards the end, I was on Nexium because the 120 miles a day commute exposed my stomach, apparently, to too much acid reflux. I felt like such a pu$$y.
