Are you guys running the AT in manual mode, ds, or auto on road course?
View Poll Results: Are you guys running the AT in manual mode, ds, or auto on road course? | |||
AUTO | 0 | 0% | |
DS | 9 | 33.33% | |
M 1-6 | 18 | 66.67% | |
Voters: 27. You may not vote on this poll |
10-31-2012, 07:13 PM | #4 |
Rep 99
Manual all the way. Definitely better to know what gear you're in when powering through a corner so you can properly throttle out. It's awful when you put your foot down and the car hesitates while searching for the right gear. The paddle shifters are there for a reason - use them!
#tailhappy
10-31-2012, 07:48 PM | #5 |
Rep 5,417
I've tried DS mode on my two day road course in NJMP Lightning. The result was pretty good on the first day to learn the track because you have less things to worry about, just drive and speed entering/exiting etc...
The second day I was ready to drive better and ready to make my car be in the right gear the whole time. I noticed that my car did keep it in the correct gear as you enter the apex for the most part, but there are a couple turns where it downshifted as you exit the apex which resulted in a hard jolt with meth and disrupts the car a bit on the exit... i'm not sure how much it would affect RWD cars as much as mine "AWD" but i managed to keep it in line when it happens, but its not the feeling you get when you shift manually and expect that kind of thing to happen when you want it. My advice is to learn M 1-6 from the start and get use to it. Its also nice to downgear and know which gears you are in as you do so... helps to determine where you should be on the track and in which gear. It actually helped me take a blind turn much better because i know i felt safe in gear 3's upper RPM vs DS which i wasn't sure what gear I was, and it was harder for me to judge how fast i really should be at that point etc... |
11-01-2012, 08:56 AM | #7 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
I would imagine DS is best, truth is you can get around a track in one gear most times. These motors are so torquey I would think you'd get by fine the one time you would've downshifted from 5th to 4th (if you weigh that against the shift lag).
11-02-2012, 05:29 PM | #8 |
Rep 116
One gear? What track are you on?!?
11-02-2012, 05:39 PM | #9 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
I once saw a car spun out in front of me when the automatic transmission downshifted at the exit of a turn when he put the hammer down.
If you don't know how to shift for yourself, at least DON'T LET THE CAR SHIFT FOR YOU. Put it in manual mode and make sure you are doing all the upshift and downshift. Car's not that smart (or good) when it comes to when to pick the shift point, especially when kick-down is involved.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
11-02-2012, 05:57 PM | #10 | |
Rep 2,301
Also note that the only way to by pass/trick the transmission logic and enter in 2nd and exit WOT into 3rd is to do a double tap of the tranny before, and mid way through the turn, forcing it to stay in 2nd. If you are not timing it well enough the tranny will upshift. I have seen NO advantage time wise with using manual mode at the track in an open differential vehicle, only a penalty of up to 3 seconds, in the turn, and loads of excessive tranny build up. Just my 2 cents.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
11-02-2012, 07:10 PM | #11 |
1821
Rep 5,337
I'm just tellin' you what I saw. An experience driver (5+ year, close to 100 days on track) in an AT spinning out in front of me due to the transmission doing things it's not suppose to. When he dropped the hammer coming out of a turn, the transmission dropped DOWN a gear and forced a spin unexpectedly (not on upshift). Dude ended up buying a MANUAL car and learning to drive stick for track use.
My opinion? If you're not in 100% control of your car on track, you're not in control of your car. Put it in manual and row your own gears rather than let the car determine it for you on track.
11-02-2012, 10:08 PM | #12 |
Rep 1,529
wow, lots of great info.
i was curious as i heard from one member that running in AT mode, he avoids the LIMP Modes, i had to say hahhh? i always run in M, sebring and homestead are 3 -4-5 gear tracks |
11-03-2012, 07:29 AM | #13 |
Rep 1,510
Manual mode always & 2 small rubber grommets under the gas pedal (see DIY section) to prevent kickdown/downshifting, I need to know what gear I'm in at all times.
11-03-2012, 10:02 AM | #14 |
Rep 386
One of the first lessons I learned in my AT is to never "drop the hammer coming out of a turn." Anyone with a modicum of track experience will generally roll into the throttle coming out of turns. Every instructor I've had has preached this, AT or not.
'07 E92 BMW 335i
11-03-2012, 09:05 PM | #15 |
Rep 12,570
I've been on 7 different tracks.
Note I said one gear can get you around, not it was the fastest. What tracks have you done that can't be done in one gear once you've gotten to speed? |
11-04-2012, 09:32 AM | #18 |
Rep 2,301
To Acj75, and DSC_OFF: There's a lot of chest-beating going on in this thread, so I quit while I was ahead.
'07 335I w/ Mods
11-05-2012, 07:10 AM | #19 |
Rep 12,570
Hardly any chest pounding on my part, someone asks me what tracks I've been on, figured better to give a number than to list them all out. And I can't see how anyone can argue that one cannot make around a track in a single gear -- so are they heel/toeing through their cool down lap? I often tell intro drivers to try to minimize shifting in order to learn the line during their first session or two, and often times depending on the car it can be done in 4th or 5th.
11-05-2012, 01:59 PM | #20 | |
1821
Rep 5,337
Once you advance past a certain basic skill level, you need to learn to figure out what feedback is right and what is wrong. The guy I was talking about has close to 100 track days under his belt at the time and I trust him implicitly when sharing a track...That should say something about what he knows and don't know. The fact is, when he had reached full throttle as he exited a turn, the automatic transmission dropped down one gear on him and caused him to spin out of control. Again. If you're not in full control of your vehicle at all times, you're not in control, period. If you have to feather the throttle longer because you're afraid of the car downshifting on you unexpectedly, you're not going to be able to extract that last 1/10th of a second out of said corner. Put the transmission in manual mode and control what gear you're in, don't let the car do the guesswork for you.
11-05-2012, 05:57 PM | #21 | |
Rep 502
Summary of the episode by Jackie Stewart 1) smooth is fast, 2) you need to be in the right gear before corner 3) and you need to get on throttle as soon as possible and hammer it when you know you do not have to let got of the throttle. http://www.youtube.com/watch?feature...&v=n5rpFXdWtK4 |
11-05-2012, 10:06 PM | #22 | |
Rep 2,301
'07 335I w/ Mods
