Mass air flow sensor
11-01-2012, 04:08 PM | #1 |
Rep 470
Is there a DIY for cleaning the mass air flow sensor? I've searched YouTube up an down and it's only showing for the e46 no e92. Let me know if anyone can help. This is the first step in solving my problem. Thank you!
\ 07' e92 335i / BSM \ Saddle Brown / Remus \ JB4 / OSS \ LCI / M3 Rep \ 20" Vossen CV3 / H&R Sport \ QI45 / |
11-01-2012, 04:21 PM | #2 |
Rep 3,004
Because we don't have one
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
11-01-2012, 04:29 PM | #3 |
Rep 470
well thats just dandy...I was hoping for an easy fix...guess not
11-01-2012, 04:50 PM | #4 |
Rep 3,004
I am assuming misfires?
11-01-2012, 06:10 PM | #6 |
Rep 470
yes cylinder 2 and 6 misfires...MAP? is there anyway to clean it or do I have to replace it?
11-01-2012, 06:11 PM | #7 |
Rep 7,377
no need to clean that, is not a MAF
11-01-2012, 06:34 PM | #9 |
Rep 470
Well is there a way to clean it or do I need to take it to the shop? Come on guys I could use your help lol
11-01-2012, 07:01 PM | #10 |
Rep 470
well I was going to rip into the engine and swap packs around...until I dropped the damn socket. Just my luck...ill be taking it to the shop tomorrow. God hates me
11-01-2012, 07:16 PM | #12 | |
Rep 470
11-01-2012, 07:54 PM | #15 |
Rep 80
For the record, MAF stand for "mass air flow" and measures the mass of the air entering the engine.
MAP stands for "manifold absolute pressure" and measures the pressure inside the intake manifold. Using a temperature sensor, the density of the air can be calculated and with the pressure being known, the mass of the air entering the engine can be calculated. |
