HELP: car is misfiring and throwing codes
11-02-2012, 12:15 PM | #1 |
Rep 143
Drives: 2008 E92 335i
I'll give you all a run-down of the past two weeks or so.
Driving around, about two weeks ago, punch it hard, car goes into limp mode. Take it to pepboys(to diagnose code) but when I turn the car back on, limp mode is gone. I bought some Seafoam fuel additive, put it in the gas. Everything went fine. This sunday, I start the car, its running really rough, sounds like it might be misfiring, but no codes show up. Let the engine warm up, rough sound goes away. Same thing, this whole week. Then today (Friday) I start the car this morning, and its running more rough than the past couple of days, service engine light comes on, and I have to keep the car at 1000 rpm or higher for fear of stalling. Start driving to the dealership, after about 5 minutes, car runs like a champ. SESL doesn't go away, so I scan it. Get these codes: P0301 P0300 P0104 Take it to the stealership, they charge me $140 to say the same thing, and tell me that it might need to have its ECU reflashed, or reset, or whatever. What is going on? Like I said, when the car sits for a little while, it runs REALLY hard on startup, but when I drive around for a bit, it seems all better NOTE: only modifications are dual cone intake, and I unplugged the exhaust diaphragm actuator (to make the exhaust louder on a 335i) I plugged it back in this morning. |
11-02-2012, 02:29 PM | #2 |
ex deus machina
124
Rep 968
Miles on the car?
How many miles on spark plugs? Carbon cleaning ever been done? Which intake do you have? Some brands position the MAF sensor too low causing all kinds of shenanigans
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
11-02-2012, 02:45 PM | #3 |
Rep 3,004
leaking injector causing a super rich startup condition. Find out which cylinders are mis-firing, replace those injectors. They can be found for 100-150 online for new ones + 8-10 dollars for decoupling units. Then find someone who can help you to code them. There is a great DIY somewhere on the forums.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
11-02-2012, 04:49 PM | #4 |
Rep 143
Awesome, thanks for the advice, it's never had a carbon cleaning or anything I don't think. It's got about 67k on it. I will try getting the dealer to replace the injectors, isn't there a factory recall or something? Maybe it is the coil pack(s)
11-03-2012, 10:32 AM | #5 | |
Rep 143
11-03-2012, 02:31 PM | #6 |
ex deus machina
124
Rep 968
Before replacing try swapping coils or injectors to a different cylinder and see if the problem moves to that cylinder
