Midpipe bracket question
11-09-2012, 09:03 AM | #1 |
Rep 145
I installed downpipes this past weekend. Apparently I didn't tighten the midpipe bracket bolt tight enough because I lost it on on the road today. I was able to go back and find the bracket but not the bolt. So my questions:
1. Is the mid pipe bracket that important? Would I be ok without it or does the exhaust need that extra support? 2. Anyone know what the size of the bolt is? Thanks
07 e92 335i / SGM / CORAL / Aero Kit / JB4 / BMS DCI / VRSF 3" DP's / Eibach Pro-Kit
11-09-2012, 09:13 AM | #2 |
Rep 7,377
11-09-2012, 09:20 AM | #3 |
210
Rep 1,161
Just a note: Don't over-tighten that bolt in reaction to your lost bolt, if it's the #12 on Enrita's RealOEM image: those will break in the top bracket if you kill them with air tools. Ask me how I know...
11-09-2012, 10:05 AM | #4 | |
Rep 145
Ya #12 is what I need. But I'm wondering if my top bracket broke as you mentioned. I left the under tray off after my install so I could get back in this weekend and re tighten everything. I went over a huge speed bump and heard the exhaust hit...shortly after is when the bracket fell off. Guess ill have to get under there and check it out.
