Gas shortage in ny is 87 ok to mix in
11-09-2012, 06:34 PM | #1 |
Rep 80
As u all prob know since hurricane sandy theres been a gas shortage in the north east, all that is available is 87 can i mix like 3-5 gallons in with the half tank of premium i have left?? Would that be ok to do? Or would that be a bad idea? I want to mix it now while i still have some premium in the tank, any responses are greatly appreciated
I baby my car just like the next guy... But I drive it like I'm raping it
11-09-2012, 06:55 PM | #3 |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
well if that's all you can do...
BMW specifically says premium. I believe. I really don't know, but I am sure you will be fine, but the car may be rough idles and throwing some timing. If you have to, I wouldn't get on it and drive like a grandma. 5 gallons of 87 would be approx. 90.7 octane. with your 8 gallons of 93. Which I run 91 here in Cali all day long. without my tune.
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
11-09-2012, 08:26 PM | #5 |
Rep 2,396
Drives: '08 E90 335i
Couple things:
Otherwise, just try to avoid driving your car. Luckily the powers starting to come back in a lot of places so getting gas might be getting back to normal over the weekend/next few days. |
11-09-2012, 08:52 PM | #7 |
Rep 1,857
+1
you'll be fine, just try to stay out of heavy boost
11-09-2012, 09:13 PM | #8 | |
Rep 80
To every one else that responded thank you, but I already mixed in the 2.5 gallons of 87 with the half tank of 93, my cars completely stock now, i have no tune, or any thing and my lease goes back in february so im pretty sure 2 gallons of reg gas wont hurt it and if it does its bmws problem in february, also i cant drive fast theres too much debris, trees and down power lines in the road also theres traffic lights out, it wouldnt be wise to speed around here now
11-09-2012, 09:15 PM | #9 |
Rep 80
On the + side this cars extremely fuel efficient when driven conservatively ive been able to get around and only use half a tank in the last week and a half since the storm
11-09-2012, 09:22 PM | #10 |
Rep 80
Bmw called me back finally and said owners manual says if only 87 is avail its ok to use that the car will automatically retard the timing but to fill up on 93 asap
11-09-2012, 11:07 PM | #11 |
Rep 961
87 will be fine. The DME will just pull timing if it needs to. I would post a disclaimer that you should baby the car, but honestly I don't even think that's necessary.
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
11-10-2012, 06:57 AM | #12 |
Rep 5,463
Car will totally compensate for 87, just will make less power as it will pull timing, but won't cause damage, just run it and get some 93 when you can. Also, do not go to autozone and buy octane booster and dump that in - that potentially is much worse than just running the straight 87.
All dealer loaner 335's get 87 all day long everyday as no one pays the extra to put 93 in them and they all survive just fine!
2025 X5 Msport
11-10-2012, 08:14 AM | #13 |
Rainbow Racer
1008
Rep 2,540
91 octane is recommended, but not required. The ability of 87 octane to ignite at a lower temperature may actually even be ideal under light-load situation's to reduce fuel consumption.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
11-12-2012, 12:49 AM | #14 |
589
Rep 897
As most of the guys here are saying. 91 is highly recommended but not required.
I would baby the throttle, and not get on it as much on 87. It will retard timing, and you will gain less power per % on throttle input. Trust me, same feeling as if you get a batch of bad gas, you'll feel like you're making less power, and need more input for the same amount of power on good gas. |
