Cobb data log and vacuum leak?
11-10-2012, 12:56 PM | #1 |
Rep 361
Is it possible to see if I have a vacuum leak with the Cobb tune? If I were to post my data log, can anyone help me to see if I have a possible vacuum leak? I will pay via paypal if anyone can help me.. thanks.
11-10-2012, 02:03 PM | #2 |
resident girl.
59
Rep 1,017
Drives: 2008 335i + 2014 X5
You can log and monitor boost/vac with the AP. You should be able to easily see via the monitor if you are not hitting target boost/vacuum numbers.
If you had a vacuum leak you should have a code, though (and/or you would probably be able to hear a loud hissing sound at idle). I had a very large vacuum leak in my E39 a couple years back. I heard it before I got a CEL. I used a mechanic's stethoscope to isolate the location. Turned out to be the rat's nest of vac lines under the intake manifold. In that case, the leak was so large that the car couldn't hold idle.
2008 E90 335i // Black Everything // photos COBB tuned / QTP e-cutouts / Helix FMIC / cp-e DCI / AWE BOVs / Catless / FBO + F15 X5 xDrive35i |
