F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M Sport Brake Vs
Extreme Powerhouse
      11-14-2012, 11:19 PM   #1
Dan_335i
Drives: 2014 335i EBII MSport
M Sport Brake Vs
Whats is worth it paying $350 to upgrade current brakes of a f30 335i to the m sport brakes. The one where you need to get msport package.
Or
Should I get BMW M Performance 18'' brakes
Inner-vented, lightweight sport brake discs. Designed for extremely sporty driving and higher thermal challenges. Four-piston aluminium caliper on the front axle, two-piston aluminium caliper on the rear axle. Available in M Performance Red, M Performance Yellow or M Performance Orange. Includes coloured M logo.
1. If I decide to go with the 18" brakes how much would it cost for parts and labour roughly?
2. Would the 18" brakes be way more of a grip then the m brakes that are a upgrade in msport package? How much % better?
      11-15-2012, 03:39 AM   #2
Vitoco
Infidel
Vitoco's Avatar
122
Drives: iX3 LCI M Pro Carbon B
The M Sport brakes and the M Performance brakes are IDENTICAL in size and all, except for that the Performance discs are slotted. Thaīs the only difference, so if u can get the M Sport brakes itīs only stupid not to take them. Unless you want red, orange or yellow calipers instead of the blue
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022
| Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts |
      11-15-2012, 10:29 AM   #3
bmrm396
Drives: 2018 F80 M3cs
Actually the rear rotors on the mperformance kit are bigger than reg msport ...
Formerly addicted to e46fanatics
Formerly addicted to e90post
      11-15-2012, 11:28 AM   #4
clarence
Drives: F30 328i M-Sport
No, M-sport brakes & M-performance brakes are identical on all four corners apart from the slotted discs on the M-perf kit.
      11-15-2012, 11:43 AM   #5
godfather87
Drives: 2013 335ix
Man, its def worth it! I wasn't gonna get it but the dealer ended up giving it to me since there were so many delays with the car etc. The brakes look sweet and everyone always tells me how nice they stand out!
$350 isn't much on a $60k plus car...i would get it again for sure!
      11-15-2012, 11:47 AM   #6
godfather87
Drives: 2013 335ix
here's a pic i took...
      11-15-2012, 11:49 AM   #7
bmrm396
Of course were neglecting whether this is a 328 or 335. If youre talkin 335 then yes, if 328 then no.
328i M sport brakes - front: 13.4" / rear: 13.6" = 340mm/345mm
335i M sport brakes - front: 14.6" front / rear: 13.6" rear = 370mm/345mm
M performance kit (all f30) -
•Front rotor size: 370mm x 30mm
•Rear rotor size*: 345mm x 24mm
And it goes without saying OP, that u must have 18" wheels or above to fit
Im friggin jealous u even get this option. Us in the US for some asinine reason, dont get msport brakes at all
      11-15-2012, 03:19 PM   #8
DerekS
DerekS's Avatar
197
Drives: '24 X3 M Sport
Believe me, it is the only option advantage for Canadian purchasers of F30-335i M Sport compared to US pricing and options.
on order: 2024 i4 eDrive40 M Sport, Tanzanite metallic with all options
      11-15-2012, 07:58 PM   #9
E34
Drives: E34 535i
smaller 328i M Sport brake rotors are mythical. there is no such thing. You can not order M Sport brakes in USA and the 328i M Sport does not exist for Canadian buyers. In the ROW all model M Sport brakes are the same size.
      11-15-2012, 10:48 PM   #10
clarence
If u're talking abt the mythical US-spec M-sport brakes then yes, but if u're talking ROW/EU-spec then no. M-sport brake is the same regardless of whether it's a 316d or a 335i.
      11-16-2012, 03:18 AM   #11
Vitoco
Infidel
Vitoco's Avatar
122
this.
      11-16-2012, 03:22 AM   #12
MaestroAl
Drives: 335xD
Do you think that the BMW marketeers who decide what "lines", what options, what packages and what general shizzle is available in what country ... all take a truck load of acid before their meetings?
"Sleeper 335D xDrive M Sport" Glacier Silver / Black
ZMS | ZNP | ZVI | 2VF | 2VL | 3AG | 494 | 6NS | 8TH
      11-16-2012, 04:05 AM   #13
Vitoco
Infidel
Vitoco's Avatar
122
      11-16-2012, 05:19 PM   #14
BavarianFanatic
Too much is never enough
Drives: Too Many
Bigger brakes does not equal better performance. It's all about the pads. You can easily outperform M Sport/M Performance brakes with the stock setup and a good set of pads. For 99% of folks the big brakes are eye candy. The only benefit of a big kit is more capacity for heat dissipation to prevent fade.
      11-16-2012, 05:41 PM   #15
Carjack
Stormtrooper
Carjack's Avatar
Drives: 330i G20 M-Sport Portimao Blue
Quote: "The only benefit of a big kit is more capacity for heat dissipation to prevent fade" ?
If you use your brakes, it is the biggest benefit!
Brake fade is the killer of all standard brakes!
      11-16-2012, 07:49 PM   #16
BavarianFanatic
Drives: Too Many
If you're experiencing fade on the street, you're doing it wrong. ;-)
      11-17-2012, 04:51 AM   #17
MaestroAl
Drives: 335xD
Damn right. I'd add to that; if you're getting brake fade on the street then you need locking up
      11-17-2012, 05:12 PM   #18
Carjack
Stormtrooper
Carjack's Avatar
On the track man! That's what the M-Sport braking system 2NH is for.
Not for ponceing down the boulavard!
      10-22-2013, 09:57 AM   #19
Steve89GTA
Drives: 2013 335 MSport Xdrive
Winter Wheels? Blue MSport Brakes
What are you guys using for winter wheels with the msport setup?
I hear there are only a few 18" that fit.
Steve
      10-22-2013, 11:29 AM   #20
oceanview
oceanview's Avatar
Drives: 335i F31 RWD Autom.
I'm going to use the 400 M
Front 8Jx18 225/45
Rear 8 1/2Jx18 255/40
with Pirelli Sottozero II RFT
      10-27-2013, 10:51 PM   #21
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
The rotors are lighter with the M performance setup...
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      10-27-2013, 11:46 PM   #22
F32
Do you have any documentation showing weights?
f30post
