Installed JB4 and now getting 30FF
11-16-2012, 12:28 PM | #1 |
Rep 4,267
Spoke to Terry and sent him the csv files i have so he could take a look. This seems to happen when i get above the stock psi settings, so even happens on map1. Never happened before the JB4 install so im guessing the increased boost has caused a leak somewhere. Car dont hit boost target at all.
Question is where? Charge pipe has been suggested as the 1st place to look but are there any other known weak areas?
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
11-16-2012, 01:09 PM | #3 |
Rep 4,267
No BOV car is in stock trim other than JB4. Got a dyno run tomorrow with a few of the UK guys so will see if we can spot anything. Hardly seems worth running when its struggling to hit target.
11-16-2012, 02:50 PM | #4 |
Joint Chiefs of Staff
4927
Rep 116,037
Rather than spending the money on a dyno you should spend it on a mechanic to fix the car. 30FF is boost leak. Since you bought the JB4 used it could just be damaged or something as well.
Mike |
11-16-2012, 02:53 PM | #5 |
Rep 4,267
I know mike, i organised the day though so would be bad not to turn up. Plus many ears and JB4 users may spot a glaring mistake, got tool kit in the boot
Gives me a excuse to update components as well .
11-16-2012, 03:05 PM | #6 |
Rep 4,267
Mike any recommendations for chargepipe and intercooler pipe upgrades? Anything you sell?
11-16-2012, 03:19 PM | #7 | |
Rep 6,136
I like the Helix FMIC the best, but ER and ETS are also top notch FMIC's that replace all the piping. |
11-16-2012, 03:37 PM | #8 |
Rep 4,267
Not showing on the UK site, FMIC is though. Really looking for just the pipework to rule out my boost loss issue. It could be the JB4 but i dont think it is as its only a few months old. Going to try map 0 tomorrow and run a few pulls. If it still leaks it must be a hose?
11-16-2012, 04:05 PM | #9 |
Rep 1,290
FWIW E90company is always very unbiased with his mod suggestions, so id check out his recommendations
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
11-16-2012, 04:06 PM | #10 | |
Rep 1,290
If you have trouble figuring it out, those lads at your meet should be able to track it down
11-16-2012, 04:18 PM | #12 |
Rep 4,267
11-16-2012, 08:12 PM | #13 |
Some dude
92
Rep 1,780
If it is not a boost leak, it is entirely possible that your wastegates are extremely worn and out of adjustment. Fixed a JB4 car with the same problem last month.
RRT
E92 335i/6MT with stuff and things |
11-17-2012, 10:41 AM | #14 |
Rep 4,267
Dyno run from today, new it was bad but, not this bad!
Car is under warranty so my plan is, get car checked for boost leak, if found then great carry on. If not then take off the JB4 clear codes and give it to the shop.
11-17-2012, 10:59 AM | #16 |
Rep 4,267
I had organised it weeks ago before the jb4 was fitted, 9 or 10 of us from the UK side went. Dyno guys gave me details for someone to check for a boost leak so not a entirely wasted day.
11-18-2012, 12:20 PM | #17 |
Stupid Idiot
134
Rep 827
So do you get the 30FF fault if you go back to stock boost levels? If it is totally fine with the JB removed, then getting any kind of warranty repair is pretty slim.
When I see a 30FF fault on stock cars, it's usually one of the EPDW's (wategate vacuum control valve) leaking or a wastegate mechanism binding/jamming. Or a broken or damaged vacuum hose. I've personally never seen a factory intercooler or bypass valve leak. If somebody left something loose, that's a different story.
11-18-2012, 12:23 PM | #18 |
Rep 4,267
On map 0 i get no codes, have been told to check the diverter valves first.
11-18-2012, 12:25 PM | #19 |
Stupid Idiot
134
Rep 827
Could be one of the valves is leaking under higher boost pressure. Definitely a possibility. Time for an upgrade maybe....
11-18-2012, 12:27 PM | #20 |
Rep 4,267
Any excuse to spend some $$$ Just been looking at the Evolution Racewerks blow off valve kit on HPF.
11-18-2012, 12:27 PM | #21 |
Rep 1,290
wait wait wait... i just thought of something, we may have covered it under your last thread... but have you tried logging a pull in map 4... just to see if you hit stock boost target levels.. based on ur dyno you hit stock boost.. If you hit target on map 4, its probably back to something wrong with the board as you said, it may have been tampered with (intentionally/unintentionally) by the previous owner. Id give that a shot for sure.
11-18-2012, 12:30 PM | #22 |
Rep 4,267
Sounds good to me bud, will give that a go tomorrow and get some logs.
