11-16-2012, 03:07 PM | #1 |
Rep 88
Odd problem today - low power
I had an odd problem today on my 2013 335 xdrive. I pulled onto an onramp and hit the gas and had almost no power and acceleration into second gear. I shifted to third and same thing. I pushed the pedal to the floor and almost no acceleration. I got off the highway and at the next light shut of the car and turned and back on and all way well. Anyone seen this?
11-16-2012, 04:15 PM | #2 |
Rep 4,323
Sounds like limp mode.
Did you run cheap Gas by accident? Did a hose clamp around your intake come loose?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
11-16-2012, 04:19 PM | #3 |
Rep 88
I've been using 93 at name brand pumps
It sure felt like limp mode but it didn't throw any codes and they car said it was ok in the information in the NAV I will check for loose clamps. |
11-18-2012, 11:44 PM | #4 |
Rep 4,959
Did you trigger the traction control by chance?
Not too long ago I lost traction and the TC intervened, cutting the power. There must've been some sort of glitch because the power cut remained until I turned the car off and then re-started it. I didn't experience any error codes or warning lights.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV Gone: '20 W205 C43 Sedan Gone: '18 W205 C43 Sedan Gone: '13 W204 C63 Sedan |
