Downpipes hurt turbos?
11-16-2012, 03:56 PM | #1 |
Rep 199
Question:
If one were to ONLY remove the cats on an N54 engine and put downpipes, would that cause the seals in the turbos to fail prematurely? Thank you for your input. |
11-16-2012, 04:15 PM | #6 |
Rep 330
Cats create back-pressure, causing the turbo to work harder and creating more heat, which kills turbos.
This is common knowledge.
FFTEC 6466 6mt 335i | FFTEC GTX3076R Evo IX
snowbunnyf300.00 |
11-16-2012, 04:20 PM | #7 | |
Rep 457
And downpipes free up the air flow no matter how u slice it. Less restriction, less resistance on all parts. Less wear, Less heat, its a win win. Only downside is your mpg will go down from the excessive flooring |
11-16-2012, 04:20 PM | #8 | |
Rep 3,396
I can see air intakes might raise eyebrows forcing more air in, over working the turbos but anything after the turbos should be welcome, no? Last edited by shortseller; 11-16-2012 at 04:26 PM.. |
11-16-2012, 04:23 PM | #9 |
Rep 3,004
+1
Less Back pressure, Less Heat...HEAT KILLS
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
11-16-2012, 04:30 PM | #10 | |
Rep 2,838
Drives: e92 335i, e34 525i & e60 530i
11-16-2012, 04:42 PM | #12 |
Rep 290
11-16-2012, 04:46 PM | #13 | |
Rep 6,136
11-16-2012, 05:09 PM | #14 | |
Rep 457
11-16-2012, 05:39 PM | #15 |
Rep 6,631
The BMW techs are only qualified to diagnose issues for vehicles in stock form, not modified.
Kind of like jailbreaking an iPhone and going to the apple store for support as to why the phone is freezing.
E90 LCI N54 6AT
11-16-2012, 07:13 PM | #16 |
Rep 50
+1
E30->E28->E34->E39->A3->E90
11-16-2012, 07:40 PM | #18 |
Rep 199
This is for a carmax warranty. They said they r denying a leaking turbo bc the car has downpipes. Just goes to show they try to cover as little as possible.
11-16-2012, 08:07 PM | #19 |
Rep 3,396
Adhering to the strict EPA thing makes sense.
11-16-2012, 08:19 PM | #20 |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
as mentioned above, messing with catalytic converters is a federal offense. you can be fined up to $20,000. that's a huge liability for anyone (dealer or independent shop) to mess with.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
11-16-2012, 08:51 PM | #21 |
Some dude
92
Rep 1,780
Also the moral of this story is: return the car to stock before trying to get any kind of warranty coverage.
No matter how many opinions you get here on the good or bad of downpipes, the warranty company doesn't care. They can deny your claim due to nonstandard modifications.
RRT
E92 335i/6MT with stuff and things |
