PTF E40 Map - Drag Racing Results
11-19-2012, 09:43 AM | #1 |
Rep 1,145
I've been having smoke problems with my car, but it seems to have subsided. Now my LPFP doesn't like E60 so Dzenno tuned me down to E40. Car seemed to be running well so I headed to the track last Friday.
The DA was about 38 I freaking suck balls at launching. Mind you this is with drag radials and a LSD... I think I need to invest in a line lock kit because my burnout skills are as good as my launching skills. |
11-19-2012, 10:22 AM | #3 |
Rep 949
He explained why he isn't in the 11s. If you look at the 60ft you'll see where he is losing the time. The car looks healthy though. Still getting good traps in the 1/8th. Fix that launch and you'll be set. It can help to let the car lurch forward in the waterbox to get momentum and then stop the front wheels and you can get a better burnout. Just takes practice
11-19-2012, 10:29 AM | #5 |
Rep 227
@nafoo - what tires are you running? What tire pressure are you using on that setup (you may be running too high)?
Since you're a 6MT, you may want to go to a nice, "isolated" parking lot and practice your smokeys. You should be able to get a decent burnout without a linelock kit.
Vishnu/FFTEC Single Turbo (58mm) 6AT ... 60-130 in 6.881 seconds
Vishnu Procede Rev.3, Vishnu PWM Meth Kit, AE Exhaust, Helix IC, Forge DVs, Wavetrac LSD #### IT'S FOR SALE ### |
11-19-2012, 10:46 AM | #7 |
Rep 1,290
just saw your MT.. those times make sense based on the 60fts
practice those launches and you will be at least low 12s
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
11-19-2012, 10:57 AM | #8 |
Rep 1,176
Your 1/4 mile mph looks strong, but like you said, your 60' times are terrible and that is what is killing your elapsed time. Keep practicing and you'll get the hang of it.
11-19-2012, 10:59 AM | #9 |
Rep 579
Drives: 08 AW e92 335i
Nice trap speed. So close to 119!
11-19-2012, 11:25 AM | #10 |
3442
Rep 79,211
Are you still spinning with DR because of lack of heat in the tire? Or are you bogging at the line?
You can cut a better 60 foot on street tires, so maybe DR isn't for you at this stage. Line lock kits are nice, but really you just need to drop the clutch with some high rev's in the water box and as soon as the tires slip apply some brakes to keep you there. If your back end starts getting swirly and trying to turn you put the clutch in and stay on the brakes (while counter steering). Some tracks tend to keep you straighter then others while doing a burn out, most people fear doing a burn out and needing to counter steer to keep the car straight. |
11-19-2012, 11:35 AM | #11 |
Rep 1,290
I think it should be a priority to get sub 2.0 on street tires before going to drag radials, otherwise you likely wont gain much. just my opinion. im trying to do better than 1.80 consitently before i go DRs
11-19-2012, 01:28 PM | #12 | ||||
Rep 1,145
MT Quote:
I'm just really bad at burning out. Definitely need to practice. Quote:
11-19-2012, 01:35 PM | #13 |
Rep 1,153
If you are getting lots of wheel spin that means you are giving too much gas too quickly. A good drill for you to do would be to try bogging down at the line. Once you can do that, gradually start giving more gas until you can find that sweet spot. An old school racer taught that to me a while back. It will take a while but practice makes perfect and it works. Also try to leave the tree on the last set of yellow lights instead of on the green. This will help with your RT.
2016 340i xdrive
2009 335i |
11-19-2012, 01:39 PM | #14 | |
Rep 1,290
This should be a sticky lol
11-19-2012, 04:12 PM | #15 | |
Rep 1,145
11-19-2012, 05:26 PM | #16 |
ex deus machina
124
Rep 968
with DR and LSD 1.6XX should be the norm...
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
11-19-2012, 05:33 PM | #17 | |
ex deus machina
124
Rep 968
At the track disconnect the rear sway bar put max pressure on front tires if your coilovers are externally adjustable set the rears to the softest setting.
11-19-2012, 05:37 PM | #18 |
Rep 1,290
I would hope to get 1.5x on radials seeing how i get mid to high 1.7s on street tires on a good launch
