E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > DP install diy question with steering rack
Reply
      11-19-2012, 01:30 PM   #1
spiike32
spiike32's Avatar
79
Drives: Mineral White F80 M3
When installing dp's do you guys recommend only unbolting the passenger side bolt of the steering rack and moving it up an inch or unbolting bolts to the steering rack and yanking the whole thing down?
DIY on the forum only moves it up and inch @ step 6
http://www.e90post.com/forums/showthread.php?t=104333
Mach schnell dp video does both but only pulls the rack up an inch @ 3:35
AR install dp video does both and yanks down the steering rack @ 9:00
The reason why I ask is because I had my entire steering rack replaced due to rack and pinion misalignment and I'm not sure if it's because I pulled the steering rack down for dp install or if it was from something else. Just want to clarify before putting dp's back in this weekend.
Current: Tesla Model 3 Performance Retired: F80 M3, FBO 335i, 318ti, C7 Stingray
      11-19-2012, 01:46 PM   #2
drm916
Drives: 335
I only removed the passsenger side and losened the drivers side. Then swung it out about an inch. Was really only necessary so you can remove the small heat shield.
      11-19-2012, 01:48 PM   #3
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Have car on jack stands, remove both bolts hex on one end and 16mm on other...this will alow you to pull the steering rack completely down....with the where's in the air you can pull it down much farther.
I will give you pics when I get home.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      11-19-2012, 01:50 PM   #4
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
if you do both sides you can move it completely out of the way (8-10"). Then unbolt 1st bolt on heat shield and swing it out of the way. I can put both arms up to my shoulders in the hole it creates lol!! Makes the job way to easy lol!
      11-19-2012, 01:53 PM   #5
rdeterman
rdeterman's Avatar
11
Drives: 2008 335i Coupe 6mt
i unbolted the whole thing.. not much more work and makes it alot easier
JB4 G5 ISO W/BMS FLASH, FBO, Walbro LPFP, Spec S2+ SMFW
      11-19-2012, 01:58 PM   #6
spiike32
spiike32's Avatar
79
Yea that's what I did the first time, but had rack and pinion issues after the install (maybe coincidence) so I am a bit worried. Thanks for the quick responses guys, excellent community.
      11-19-2012, 03:19 PM   #7
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
it does not change anything (no adjustment) just a fixed location.
      11-25-2012, 11:21 PM   #8
Flava
Drives: 2007 335i
I also removed the whole steering rack. It gave me a lot more room to work with that's for sure.
      11-25-2012, 11:31 PM   #9
GetSomeE92
Drives: '09 Space Gray E92
Is an alignment necessary after messing with the steering rack?
      01-07-2013, 10:54 PM   #10
Flava
Drives: 2007 335i
I didn't notice that my alignment was off at all afterwards
      01-07-2013, 11:07 PM   #11
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
no, tie rods are not moved.
Reply
e90post
