How to detect a Cobb (or non-piggyback)?
11-22-2012, 09:51 PM | #1 |
Rep 134
So I recently bought my car used and it's apparent the previous owner tweaked some things here and there on the car. Is there a way to see if he tuned it? I've checked the ECU and there is no piggyback module. How can you tell if there is a Cobb or the like downloaded without running a dyno?
11-22-2012, 09:55 PM | #2 |
Rep 1,950
Drives: 335i
I doubt anyone would leave the Cobb in. Its plain stupid as they can uninstall it and sell the Cobb I don't know about A Dinan or GIAC
11-22-2012, 10:15 PM | #3 |
resident girl.
59
Rep 1,017
Drives: 2008 335i + 2014 X5
It's near impossible. Ask me how I know.
The major flash tunes are Cobb, GIAC and Dinan. Call or email a GIAC dealer in your area; they'll be able to run your VIN and tell you if your car is in their database. A dealer would be able to tell you if it's Dinan, and Cobb can also run your VIN. It's likely an open source dyno tune, though, which you will likely never get to the bottom of if you can't get a hold of the previous owner.
2008 E90 335i // Black Everything // photos COBB tuned / QTP e-cutouts / Helix FMIC / cp-e DCI / AWE BOVs / Catless / FBO + F15 X5 xDrive35i |
11-22-2012, 10:43 PM | #5 |
Rep 2,396
Drives: '08 E90 335i
Only way to see if a COBB unit is installed is try to install another AP onto it. If the DME's "married" to a different AP, then it wont let you install the tune on the 2nd AccessPORT.
With the other major flashes (GIAC, Dinan, Renntech, etc), you're gonna need to call the tuner & run your VIN |
11-23-2012, 10:25 AM | #7 | |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
OP, a question you should have asked before buying. But most likely the tune was removed and or uninstalled. Good luck and enjoy your new car.
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
11-23-2012, 10:39 AM | #8 |
Rep 134
^ Bought through a dealer, no info on the previous owner (though I'm sure I could track him down if I had to).
I'll probably just have the dealer flash back to stock so I know where I'm starting from. Thanks for the input! |
11-23-2012, 11:23 AM | #9 |
Rep 1,196
You never really said why you think the DME has been messed with. Does the car run more boost than stock?
There might not be anything done to it. A dealer flash is going to cost you a good chunk of change so you might want to be sure first. |
11-23-2012, 12:15 PM | #10 |
3442
Rep 79,211
Actually if there is a tune you can just hook up a boost gauge and see if you are boosting over 10 PSI most of the time. That is the cheapest way if the other ideas dont work. Stock boost is between 7-10 depending on conditions.
Typical flash would boost atleast 15 PSI tapering to 12 or 11. Dinan might be a little less. |
11-23-2012, 02:43 PM | #11 | |
resident girl.
59
Rep 1,017
11-23-2012, 03:13 PM | #12 |
335
32
Rep 306
this.
Stock boost would be around 8.5psi or 0.6 bar. If your has software (jb, procede, cobb, custom remapping etc) on it, then you would have greater boost varying from 11 to 20 psi)
Too much mods to list.. |
11-25-2012, 01:53 PM | #13 |
Rep 134
Just bought a JB4 so I'll run the stock map and see what the boost is at.
The reason I'm suspicious is my car blew it's turbos a whopping one week after I got it. I want to make sure it's not because of an overboost from a flash tune (or maybe the previous owner removed some mods but never reduced the boost and all of the above caused the turbos to go kapuut). Whatever it is, I want to do what I can to make sure it doesn't happen again anytime soon. |
11-25-2012, 01:59 PM | #14 | |
3442
Rep 79,211
11-25-2012, 03:52 PM | #16 |
Rep 1,677
That's just shady dealer. IMO.
Most likely there is no tune, if there is then the.dealer sold you a modified car and then I bet you have a case for free replacement and or return. Obviously it's not CPO? Edit: how many miles on the car when you bought ? I may have misunderstood you, it.sounded like you bought.the car then shortly after.turbos blew.
11-26-2012, 08:40 AM | #17 |
Rep 134
It's not CPO.
Car had ~82.25k miles on it when I bought it. Engine malfunction light (30FF - low boost pressure) light came on at ~82.50k miles. Took it to the dealer, dealer says turbos are blown. I'm not sure if the turbos blew right after I bought it or if I got the car with blown turbos and I just didn't trip the indicator until 82.5k miles. Either way, it's looking like a new set of turbos for me paid out of pocket. |
11-26-2012, 08:46 AM | #18 | |
Rep 7,377
11-26-2012, 11:06 AM | #19 | |
Rep 1,677
Notify BMWNA about this shady dealer. Was it a certified dealer?. But in the end Caveat Emptor!
11-26-2012, 11:11 AM | #20 |
Rep 134
Not a certified dealer either... I live I learn...
BMWNA has told me 82k is 82k and they aren't going to help me out on this one iota. That made me pretty angry but whatever, I knew I'd have to replace the turbos eventually, I just wasn't planning on doing it 250 miles after buying the car. I'm still holding out hope that the turbos are only failing "low boost" because a flash tune is setting the reference level at like 15 psi instead of stock 8-9 psi and if I piggyback my ecu, run a lower boost, everything will be hunky dory. At least that's my current (and last) hope... |
11-26-2012, 11:15 AM | #21 | |
Rep 1,677
11-26-2012, 01:04 PM | #22 |
Rep 134
I wish... Don't want to have to replace my tranny as well (AT... had to sell my MT car b/c the wife couldn't drive it, nor had any desire to but at least I got a faster car out of the deal).
