RB turbos on 335is???
11-23-2012, 07:31 PM | #1 |
Rep 646
anyone done this yet?
im thinking of ordering some this christmas for my self im not sure if the dct is gona hold it is their any 1m with upgraded turbos since it should be the same tranny? if i do the rbs im thinking e85 + cobb pro tune current mods are ar downpipes an afe stage 2 intake would i have to add intercooler? |
11-23-2012, 07:54 PM | #2 | |
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
also, you may need to reinforce the DCT to withstand that kind of power. BuraQ is our local 335is expert here on E90Post. Im sure he will direct you right
11-24-2012, 03:35 AM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
FMIC + LSD then get the turbos.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
11-24-2012, 06:15 AM | #7 |
Rep 2,563
In Germany there have been a number of failures of the DCT with high torque tunes, even on stock turbos. I would not recommend running the RBs without upgrading the DCT, as it's also quite expensive to repair.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
11-24-2012, 02:10 PM | #8 |
Rep 2,396
Drives: '08 E90 335i
No proven, successful DCT upgrade (on the 135, 335is or M3 front for the supercharged ppls).... Until a reliable upgraded clutch/clutch plate is released for the DCT, even FBO power will stock turbos have been killing the DCT.
I would def add an FMIC as your next mod, especially before you even consider a turbo upgrade. IMO, it depends on whether you're gonna track (whether its 1/4 miles or actually track racing) or if it's gonna stay on the street. IMO, the 335is has a very good sport suspension & maybe more aggressive springs/sleeve-over kit would be sufficient for street applications. Obviously if the car's gonna see the track, bushings, coil-overs, brakes & LSD would make much more sense then upgrading the snails. |
11-24-2012, 03:29 PM | #9 |
Rep 646
i have 463tq already an i have no problems at all with the dct? am i just getting lucky
11-24-2012, 03:29 PM | #10 | |
Rep 646
11-24-2012, 03:30 PM | #11 |
Rep 2,799
Again, it is your car, and if you have the money time and patience to back it, then go for the RBs, but if you're afraid of your trans failing, steer clear of upgraded turbos
thanks to MGallop |
11-24-2012, 03:48 PM | #13 | |
Rep 4,392
You want to get the softer clutch upgrade set. Cost is about $2200 which can hold 600+ whp |
11-24-2012, 04:45 PM | #14 |
Rep 961
If you want to go upgraded turbos then go for it. Once the turbos are in then you can have the car tuned however you want to. You can make the same 460wtq(or less) but carry the curve out to make way more HP and be a lot faster and go easier on the trans. Then you can put some more thought into beefing up the transmission.
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
11-24-2012, 06:49 PM | #15 |
Rep 646
11-24-2012, 06:59 PM | #16 |
Rep 4,392
11-25-2012, 04:47 PM | #17 | |
Rep 2,396
Not that it's a bad thing, but right now stick to OEM replacement parts |
11-25-2012, 06:30 PM | #18 |
Rep 1
Other than throwing in different clutches and steels has anyone looked at machining the drum to fit an extra OE clutch and steel in? Extra clamping power but the OE materials.
11-25-2012, 07:01 PM | #19 |
Rep 2,396
Big Money project, especially when the OEM components can still keep pace with the power levels we're producing.
11-25-2012, 11:59 PM | #20 |
Rep 156
What about a Single turbo?
It looks like that for now, It's a toss up if anything..if you want to run RB's on the unknown threshold DCT in the 335is....You could possibly pull it off..but with risk. Would need to be careful and run the system at a limit with RB's as others have said if you want to keep it going......Also, what about the Single turbo setups for the N54 (Vishnu) while we are on the subject, would that fit and work on the 335is w/ DCT or do they not support it...I am guessing its the same case as the RB's? Interested to know if anyone has tried a single on the 335is. Being the car has supporting mods and future DCT upgrade planning.....Interested to know the 335is is a great platform but the DCT is the only unknown (for now) power limit...And since the single would have more lag but have a violent kick in power...Would that yield a harder wear on the DCT on paper or would the RB's turbo setup put more wear with higher torque....Just out of curiousity if both cars are turned on a conservative level.
| 2012 E92 335is- 6MT |
