11-27-2012, 12:14 PM | #1 |
Rep 258
So is the N55 a much more reliable motor than the N54?
I know this has probably been beaten to death, but would like to know first hand impressions.
11-27-2012, 01:14 PM | #2 |
Rep 3,332
There's no such thing as an "impression" when it comes to reliability, just statistics.
Since anyone on an internet forum would be making up results out of thin air, or based on claims like consumer reports, etc, it's not worth having a discussion. If you asked a BMW quality engineer, I'm going to take a guess and say yes, the N55 is more reliable. Why? Because they sat there for 4 years and analyzed all the failures on the N54 and redesigned it to improve the quality (go Six Sigma!).
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
11-27-2012, 07:57 PM | #4 |
BMW Certified Technician
Rep 19
I saw one N55 car at work that killed a head and crank, then seized solid.
Other then that, they are pretty good, as long as you do in between oil changes, you'll be fine. |
11-27-2012, 08:29 PM | #5 |
Rep 802
Sorry ... in between the standard 24k km regularly scheduled oil changes???
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
11-27-2012, 09:34 PM | #7 | |
Rep 4,323
Regular 15k changes wouldn't be factory standard otherwise... It costs them more to replace an engine than change the oil.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
11-27-2012, 09:56 PM | #9 |
Rep 6,248
The HPFP got redesigned for all F30s, and post-March 2012 E92/E93 cars. So, some N55 cars do have the old design. In other words, you can't correlate HPFP with just all N55 vs. N54 cars.
12-19-2012, 06:51 PM | #10 |
Rep 34
Both engines are good IMO. The main difference is the exhaust. The new N55 engine has one exhaust pipe the feeds from all 6 cylinder (for less fuel consumption) while the N54 had 2 pipes, one feeding from cylinders 1, 2, and 3 and another pipe feeding from cylinders 4, 5, and 6.
12-19-2012, 08:44 PM | #11 |
Rep 4,323
Well there were 2 turbos in the N54 so you kind of needed 2 pipes no?
01-22-2013, 09:02 PM | #13 |
Rep 4,553
The N55 is only as reliable as the one BMW built for you. And how well you take care of it.
Overall the N54 is a more complicated design. It also has some higher end components such as the piezo injectors and true dual turbos. N55 is what most would consider a cost reduced version of the N54. |
01-23-2013, 08:32 AM | #14 | |
Rep 4,323
I took my car in for service this morning, to replace the fabled Rusty Seat Frames and deal with some minor squeaks. The Loaner F30 328xi they gave me, mind you with 10 miles on the odo, threw an alert after driving for 5 miles that the engine oil pressure is too low...BRAND NEW 328xi and already has issues. I'm unsure I'll own another BMW after this one, given how hit or miss their build quality has been thus far...they loaned me a E90 328i, with 11k on the odo, nary an issue. The steering feel is pretty nice too....
01-23-2013, 09:46 AM | #15 | |
Rep 5,803
F30 330i Alpine white/Coral red Msport 6MT
01-23-2013, 10:18 AM | #16 | |
Rep 4,323
There's NO excuse for an engine issue like low oil pressure on a new car - even if the sensor is faulty because it was below freezing and the oil hadn't warmed up, if the warning WAS correct, I would've grenaded the engine. That's pathetic.
01-23-2013, 11:49 AM | #17 | |
Rep 5,803
Regardless, there are always going to be a few bad apples. Any other car manufacturer has similar issues. Not every car is going to be perfect.
01-26-2013, 10:44 AM | #18 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
HPFP faliures on these cars or driving around a P car with intermediate shaft that is a ticking time bomb and ready to grenade at any given moment without notice, wich by the way a crate motor from Porsche is 19k. Yeah Id take the HPFP problems 2-3 hours at the dealer and youre on your way Honestly no one knows yet if n55 is better. So far so good, but it has its own share of small issues.
FBO-PS1 and stuff
01-26-2013, 12:01 PM | #19 | |
Rep 4,323
So far, knock on wood, I've only had surface/cosmetic type issues with my 335i - engine has been strong (so far only consumed a quart of oil in 7500 miles), suspension has been awesome (after the upgrade), brakes haven't squealed, and I've enjoyed 28-30 mpg. I just wonder what troubles are coming down the pike...or if I'm in the clear. Was one reason why I got the 100k warranty, once I started having problems, I wanted some peace of mind.
02-02-2013, 07:14 AM | #20 | |
Rep 3,288
Drives: anything given a chance
OP -If you're just a daily driver with ambition, it's not going to matter to you. |
08-03-2013, 10:13 PM | #21 |
Rep 9
N55 Data Sheet
Overall I would recommend reading the data sheet for the engine to determine the differences yourself and make your own call. I will try to attach a copy. When discussing reliability it appears that the connecting rods to the pistons have been redesigned to better distribute the load placed on them. The VANOS oil passages in the engine are less complex, the oil management of the engine has had multiple overhauls compared to the n54 with changes to the crankcase and oil pan, and oil pump. It mentions that the HPFP is still the same design as the N54, and covers the difference in the fuel injectors from the Piezo-electric ones to Bosch.
Overall I would be willing to bet that the N55 would be more reliable as mentioned earlier for the simple fact that they took data from the N54 and improved upon many systems. I can't say whether or not the change in forged parts will affect reliability when tuned. Seeing as the engine is currently having issues reaching 400hp due to the twin scroll turbo limitations I doubt you will ever run into power levels that would make these parts a necessity. That is speculation tho. Only time will really tell |
