E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Help Please. JB4
Reply
      11-27-2012, 05:43 PM   #1
awesome82
awesome82's Avatar
9
Drives: gtr
Help Please. JB4
Current Mods
JB4 G5 board
DCI
Catless downpipe
Muffler delete
Charge Pipe w BOV
So i have a local muffler shop install my Catless downpipe and when they did they crossed the O2 sensors. as may of you know the car throws a code and starts running incredibly rough with this
I had the o2 sensors put back correctly and the car still doesnt run right ONLY WITH THE JB4 (any map it does the same thing)
with the JB4 off, the car runs great (throws a CEL i am assuming bc the catless dp) but runs great, slow but great
As soon as i up the JB4 on the CELS go away, and once the car goes into full boost, the car starts shaking and throws another cel. This happens on any map
Any ideas?
the car is at TKX currently and they are waiting for someone to come down and read the code
      11-27-2012, 05:47 PM   #2
MrRetep
MrRetep's Avatar
107
Drives: 435i M-Sport
the JB4 can be used to read the codes. maybe a misfire?
      11-27-2012, 05:51 PM   #3
awesome82
awesome82's Avatar
9
Drives: gtr
i was thinking the same thing.. I guess i will have 2 call them tomorrow
I would think they would know that
      11-27-2012, 08:04 PM   #4
AK 335i
AK 335i's Avatar
48
Drives: black 335i E90
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
      11-27-2012, 08:11 PM   #5
Exzackt
Exzackt's Avatar
Drives: n54 e92 335i/e39 540i6
Definitely sounds like a misfire.. When adding lbs of boost, parts that would often need to be replaced, because they were already on their way out. Try spark plugs first. Then ignition coils. If neither of these two then high pressure fuel pump or injectors. How smooth does your car idle? If rough than you might want to clean your intake valves.
2007 BSM 335i ZSP/ZPP l JB4 G5 ISO l E85 l BMS FLASH l METH l DCI l DPs l Twin BOVs l
Scoops l 18" Forgestar F14sl Koni Yellows l Swift Spec-R l GForce Rivals/Slicks l Quaife LSD
      11-27-2012, 11:55 PM   #6
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
I would like some clarification,
- The car had a JB4 installed and was running ok
-after downpipes install with incorrect O2’s runs bad
-O2 sensors corrected but still runs bad (how was it discovered that the O2 sensors were switched, it’s possible they were damaged and now need replacement)
You might need to do a hard rest of the DME by unplugging the battery overnight
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      11-28-2012, 10:47 AM   #7
awesome82
awesome82's Avatar
9
Drives: gtr
-Yes Jb4 was in for several months and car ran great
-correct
-I went to autocature in NJ and they check the code and corrected the issue (the car ran fine with the jb4 off after this as prior the car ran like shit constantly)
I might add that it doesnt happen EVERY pull... id say 98% of the time
i am thinking it either
Bad o2 sensors from when they were switched (idk if they go bad)
or plugs and or coils.
Car has 45k on it and im sure were never changed (bought it used)
      11-28-2012, 10:51 AM   #8
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Probably spark plugs if they are original.
      11-28-2012, 10:56 AM   #9
WilliamS
GoofBall
Drives: 2008 E92 N54 Xdrive
First you can reset all learned values by using Category 1 selection 7 will clear adaptations. Try that bcuase you might not be fueling properly due the air amounts. Are you 100% sure the 02's are in the right place. Turn off the Autoclear Check light codes. If you dont know if you have it on go to screen 1 and use option 4 and get out of the menu as normal when you use the track down button on your steering wheel.
Car idle do the 1/7 clear adaptations let it idle for a little bit. Go to map 4, which is factory boost but allows the JB4 to keep track of codes and such. Drive the car 10 miles, some boost some without. From there go to map 5 and drive again. If your still getting a stumble use the JB4 to figure out what codes. If it throws a code, use the JB4 to figure out what it did and why. If its a missfire use the cable to see what your long term and short term fuel trims are. As well note which cylinder the missfire was on.
Report back when your done.
Reply
e90post
