07 335i With Oil Cooler What Cobb Map?
12-01-2012, 10:54 AM | #1 |
Rep 79
OK, I just got my Cobb in the mail. My car is stock with the factory oil cooler. What map should I be running. Can I run the Stage 1 aggressive? I was going to call Cobb but they are closed today. Thanks for any info
Yes I only use 93 octane in my car.
2007 335i sport sedan fully loaded, fmc, downpipes, PTF custom tune. Sold
2012 X5 50i fully loaded. ESS TUNE 2017 X5 M Donington Grey |
12-01-2012, 11:05 AM | #3 |
Rep 79
OK. Thanks
My car is an auto but I think I can keep in 3rd with the paddles in DS mode.
12-01-2012, 11:13 AM | #4 | |
Rep 961
This should help if you have any questions about data logging http://www.e90post.com/forums/showthread.php?t=696472
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
12-01-2012, 01:00 PM | #5 |
Rep 2,396
Drives: '08 E90 335i
Since you're completely stock & running 93 octane, Stage 1 Aggressive is the appropriate Map for your car.
Put the car DS & then shift the gears so you get into M3. From there start recording your data log from 2.5k & run it full throttle to 6.5k. If conditions allow, run the car with DTC completely off while you take the log. I'd recommend for ease of reading that you reset to Default Log Reading & then switch the AP to Data Log Timing Corrections from Cylinders 1-6 & Cylinder Timing on Cylinder 3-5 (pick one) for the most accurate results. Try to at least get 3 quality logs to ensure you're consistently not getting timing corrections & holding the proper boost levels. |
12-01-2012, 01:55 PM | #6 |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
Watch out for the kick down switch..
Muahahahaha Hahahaha Haaaaa
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
