Mr 5 Intake Installed
12-02-2012, 05:32 PM | #1 |
Rep 1,504
I just completed my Mr 5 intake install. I used a 6" K&N cone and a K&N drop in panel filter and a crush proof 3" hose from McMaster. There are plenty of write ups, so I only intend to share my notes:
1. I tried to rotate the power steering reservoir and remount but the clearance just wasn't enough. I made a bracket and mounted. 2. There is a support brace under the power steering reservoir mount that needs to be removed so the hose can pass through. If you just drill out the spot welds it falls off. This will save you time, cut off wheels on your Dremel, and product a cleaner result. 3. Since road racers agree unanimously that the brake ducts are useless, I pirated mine to direct air to the cone filter. I removed the outside half and them made a cut on the remaining half just after it curves. Not sure if it makes a benefit, but I like the concept and the way it curves. 4. I used JBWeld to attach a piece of plastic in the inner fender well where the brake duct was exiting. I was worried about water and sort being flung directly onto the filter and also just dirtying up the inside of the bumper in general. 5. If you don't use the factory clip/spot for the brake boost tube, the good will close fine and this will eliminate any worry that the T junction is being stressed or pinched. Total cost was about $135. I sold my DCI for $60, so not a bad investment. I went this route because I couldn't get over the thought of hot air intake. Yes the tests have been run, but I still always longed for a better solution, or at least conceptually this is better. I went for a test drive and the car feels the same as when I had the DCI. The engine bay is MUCH quieter. Pics:
2011.5 E90 M3 DCT ZCP Slicktop
12-02-2012, 09:37 PM | #3 |
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
Thanks for the pictures and info.
Ive been wondering if a CAI type would be better than a DCI type for Florida because of crazy temps here....
12-02-2012, 09:41 PM | #4 |
Rep 1,196
I'm still very skeptical of this mod and I doubt that it actually gives any advantage at all. That long intake tube will make the motor work harder to breath, how much harder has yet to be determined. Just go try and breath through a garden hose yourself and see what happens, it called dead space. You physically cant do it.
12-02-2012, 10:04 PM | #5 | |
Rep 104
12-02-2012, 10:06 PM | #6 | |
Person of Interest
20
Rep 290
The Mr 5 intake provides an additional, secondary air intake path. The stock snorkel and panel filters are still there, doing what they've always done. The Mr 5 now adds an additional filtered air channel. By its very nature, this setup cannot be more restrictive than the oem setup. The same concept applies to the question of hydrolock. If the additional Mr. 5 filter is completely blocked, the oem intake still has the oem kidney grill source. |
12-02-2012, 10:12 PM | #7 | ||
Rep 1,504
12-02-2012, 10:15 PM | #8 | |
Rep 1,504
12-02-2012, 10:18 PM | #9 |
Rep 2,638
The dinan ram air draws from the same place and don't dinan products retain factory warranty? This is secondary proof but I would assume if it is as bad and "dangerous" as people think, Dinan wouldn't put it out and BMW wouldn't maintain warranty after using such a device.
12-02-2012, 10:29 PM | #10 |
Rep 1,529
The real answer is logging iat with each. I did, and there is negligible difference. Not worth the hassle of cleaning stock and cone filter and is a pita to get to.
12-02-2012, 10:42 PM | #13 | |
Rep 1,504
This was a thread I started to show a few pictures from my install. I stated why I wanted a Mr 5 over DCI, even said it was mostly in my head. Quit being a troll in my thread. This was never a thread saying which was better. Some guys asked a few question, but nobody is debating which is better. Both work, it's proven. Mr 5 agrees, Terry agrees. Case closed, troll
06-14-2014, 01:44 AM | #14 |
Rep 823
Drives: 2008 335i Coupe TIAG
i just made the same intake....is it absolutely necessary to remove front bumper in order to run the duct in the front like that? =\
06-14-2014, 10:44 PM | #15 |
Rep 578
Drives: 2009 335i xDrive coupe
I did this mod and did not have to remove the front bumper. You do have to remove the front left wheel fender liner. Mine fits great, works great, and it looks almost factory. I actually used one of my BMS DCI filters and metal tube for the bumper intake and I dropped a K&N in my factory intake box. I had injen, BMS dci, and now this. This is by far the best. It looks less rice boy racer (injen) and has a more oem clean look than the two filters just sitting in the hot engine bay (BMS) with no heat shields. It basically adds another cool channel of air to the already good stock setup. I also have the intake scoops which may or may not help.
06-15-2014, 07:41 PM | #16 | |
Rep 823
06-15-2014, 08:19 PM | #18 |
Rep 578
06-16-2014, 03:55 PM | #19 |
Rep 2,114
The major reason I don't run this intake over DCI's is for accessibility to the engine bay. Yes, it's lazy and it doesn't look as good, but if there's no massive difference in performance then I don't see the point in replacing the DCI's.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
