Oil around my spark plug cylinder #2
12-04-2012, 11:38 PM | #1 |
King of the road
18
Rep 202
Hey guys few days ago my car started to cut out and hesitate eventually misfiring on WOT... scanned it and it said missfire on cylinder 2. I had this happen when i first bought the car but on #6 it ended up being a coil pack. I figured it was the same thing so decided to change the coil pack on #2, once i took the old coil pack out i noticed there was oil on the end rubber tip of the coil pack and some oil deep down around the plug? What could be the cause of this ? im assuming valve cover gasket ? is there a possibility oil could have creeped through from a spill while filling it from an oil change ? Already checked all other cylinders and only #2 had the bit of oil in it... Anyone else have this happen ??
12-05-2012, 12:03 AM | #3 |
Rep 4,732
Drives: Alpine White '13 550i
12-05-2012, 12:04 AM | #4 |
Rep 2,396
Drives: '08 E90 335i
Valve cover gasket -- Just another component in the N54 that doesn't last. Not as bad as the HPFP, but the gasket, fuel injectors & waste gates are bigger headaches then they should be
12-05-2012, 12:07 AM | #5 |
Shake and Bake
32
Rep 494
Lucky for you someone just posted a diy, http://www.e90post.com/forums/showthread.php?t=775317
12-05-2012, 12:13 AM | #6 |
King of the road
18
Rep 202
Thanks for the input everyone! I also assumed valve cover gasket right away to... seems to be a common problem on all the bmw's I've owned with a straight 6 actually haha. Just thought id check with the community . I cleaned all the oil around the plug on cylinder #2 and the car isn't misfiring anymore... if it obviously is the valve cover the oil will build up again in there shortly and i'll be back to square one, Then i'll be replacing the valve cover gasket... Surprised the valve cover went this quick considering my old E46 330i's went around 180Km im only at 130Km on my n54
12-06-2012, 07:34 AM | #7 |
Rep 3,456
Drives: Harrop E90 M3
Clean it well and run the engine while watching the area of the leak to see where it is coming from. A lot of valve covers develop cracks by cylinder #2 from the inside out. Right where the front edge of the crankcase vent valve is. The valve covers aren't that difficult, but you don't want to do it twice of you don't have to.
09-27-2014, 10:23 AM | #9 |
Rep 6,478
Oil around the threads, but not on the business end = VCG. 99% of the time.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
09-27-2014, 10:48 AM | #11 |
Rep 6,478
The only thing that sucks more than our VCGs are our PS Reservoirs.
If yours isn't leaking, you aren't driving a BM. Lol.
09-27-2014, 11:56 AM | #12 | |
Rep 1,340
09-28-2014, 03:00 AM | #13 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Make sure you didn't spill any oil when adding to your car. I simply got a lil shaky and it ran down my engine cover down into the plug recess. Found it doing my plugs. I was all worried and I ran through my motor like a tweeker and nothing was wrong. It's common for #3& 4 to be dirty. I would clean everything real good and check back.
09-28-2014, 09:38 AM | #14 | |
Rep 2,189
I swear I even saw a thread where they just put a CHF 11 sticker on the top of it and below that sticker the mold of the PS res still says ATF. Thankfully these reservoirs are easy to swap out, just probably a bit messy. |
09-28-2014, 10:29 AM | #15 | |
Rep 6,478
09-30-2014, 01:39 PM | #17 |
Rep 385
Wipe the plug next time. If the oil is brand-new type of clean, you just spilled some. If it's not clean, it's like everyone else has said, valve cover gasket.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
Tags |
335i, bmw, n54, oil |
