JL 10W6v2 Subwoofer in Custom Corner Enclosure (OEM look) - Sedan Only!
12-05-2012, 04:25 PM | #1 |
Rep 3,969
SOLD! Price lowered to $350, buyer pays shipping. EDIT: e90 sedan only, does not fit e91, e92 or e93. Sub is dual 4 ohm, currently wired for 2 ohm total. VP Electricity enclosure. JL Audio grille. Everything appr. 2-3 years old. I'm the second owner. Had this running on 500 clean watts from a JL HD900/5 amp. *** This is an SQ set-up *** Corner loading "amplifies" the sound waves and produces extremely clean, up-front bass with very little to no rattles. This will not shake your car apart, but it will be the perfect addition to an existing L7 system or an SQ based aftermarket system. It will easily get as loud as two 10" woofers in a standard enclosure, minus the rattles. Blends very well with front stage, especially when polarity is reversed. Note, the sub mounting flange diameter is slightly larger than the recessed opening of the enclosure. The previous owner ground the metal on the outside of the flange to make it fit into the opening. From what I remember the amount of metal removed is very little. You don't see this since the sub is fully recessed into the enclosure. I'm just mentioning this in case someone wants to use this sub top-mounted in another application, in which case the rough surface of the flange would be visible. Thanks for looking!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
12-07-2012, 07:51 AM | #4 |
Rep 3,969
Still available. You will not find this particular setup anywhere else. The 10w6v2 is known to be the ultimate SQ sub and its specs are perfect for this enclosure. If you want to buy this enclosure new you need to buy it with sub and amp at retail pricing. Compared to the top of the line Morel sub the W6 has 60% more xmax which means it will get louder while sounding just as good as the Morel does.
12-08-2012, 11:38 AM | #5 |
Rep 3,969
Price lowered to $400!
12-09-2012, 12:29 PM | #6 |
Rep 3,969
It is very easy to add this to your existing Logic 7 or HiFi system. You will need:
The install itself is super easy and can be done by just about anyone. There are plenty of threads documenting such an install. For those on a budget, I would recommend the Kenwood XR-1S amp which can be picked-up new on eBay for around $220 or even less refurbed or used. I used to run that same amp and have only positive things to say about it. It is small, efficient, and yet very powerful, and it can be tucked away under the trunk floor and won't strain your electrical system. For not very much more, you can also pick-up a JL XD600/1 and make it an all JL combo! Whoever buys this, I will offer free email support in getting this sub installed.
12-11-2012, 05:58 AM | #8 |
Rep 3,969
12-11-2012, 07:47 AM | #9 |
Rep 1,282
Im in Greenville, SC and very interested in setup. Where exactly are you located?
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
12-11-2012, 09:01 AM | #10 |
Rep 3,969
PM sent!
12-11-2012, 05:33 PM | #11 |
Rep 3,969
Still available!
12-11-2012, 06:19 PM | #13 |
Rep 4,635
i have a 12 inch w6 and I agree that its one of the best subs you can buy
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
12-11-2012, 07:38 PM | #14 | |
Rep 3,969
12-12-2012, 07:40 AM | #15 |
Rep 3,969
Bump, lots of nibbles but no bites. This IS going to be gone by the end of the week!
