help!~the bank2 is max~!!!
12-06-2012, 02:36 AM | #1 |
Rep 283
Hey guys
The RB turbos installed my car in last week. I 'm runing the 9-10map FBO upgread map,and set the limt @19psi start@85%,OL 90 and 100%,but I can see my bank2 is max with all WOT. plz help me,because I dont what can I do,I changge 6injects yesterday and changge the HPFP in July,I have changge my LPFP sensor in last week,but its not to do sth. and I also change my valve cover in today,because I has crack on my cover.the plug and coil is the first changge.my car is 03/2010 n54 6at,and its has 35,000 miles. MOD procede v5 rev3 vishnu pwm kit and meth100% AFE DCI Forge FMIC and BV AR catless downpipes RB turbos this is my map4 log and map2 log today,I 'm use ron98 gas,its like 91oct in US. plz help me,I cant send my DME to America,because I am in China. thanks so much!!:con fused2 Last edited by diddlkiss; 12-06-2012 at 02:48 AM.. |
12-06-2012, 03:33 AM | #2 |
Rep 7,377
why dont you ditch the procede and get COBB so you stop getting headaches.
Apparently you cannot handle the procede so get something easier to use and get it protuned by PTF.
12-06-2012, 04:05 AM | #4 |
Rep 7,377
of course you can buy cobb ....
12-06-2012, 04:14 AM | #5 |
Rep 283
when I was stock turbo,I am rinning stage2 map and set boost like this,19and 85%,the fuel trim is 25%/30。if I set meth 35%,.its 25% now😓
I get the inject and lpfp sensor is very exactly,and my car is 100000dollars…If I m in America,I think I can buy a GTR35😓😓😓😓 |
12-06-2012, 06:36 AM | #6 |
Rep 1,551
I've told you in every one of your five threads that you've started for the same issue. You need to flash your DME with Cobb/vishnu or inject more meth. Stop starting new threads for the same issue.
12-06-2012, 08:15 AM | #8 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Then u buy Cobb, why u cheap? Buy Cobb NAO!
12-06-2012, 09:06 AM | #9 | |
Rep 1,551
1) Buy a Cobb and flash your DME fuel tables at home. 2) Buy bigger meth nozzles. You have two 1.0mm nozzles now, use two 1.2mm nozzles. 3) Drop boost. You are running 19psi on RBs. Do you not understand that the car CANNOT PROVIDE ENOGUH FUEL? |
12-06-2012, 10:18 AM | #11 | |
Rep 283
I think if I buy a COBB, I can at home lifted DME limit on the amount of fuel injection, and I know my car now is because of the use of a large turbocharger, causing a lot of air into the cylinders more air means more fuel is needed, but my car can not provide enough fuel to cope with these air. I do not want to give up PROCEDE, because it works very well. PWM kit works great! Can I use COBB in map0? PROCEDE map 1 2 and 4? If I were in the United States or Europe, this all will become very simple But I am in China, there is no good technical support, no one to sell as COBB ₆. If I buy a COBB, learn how to use it will be very difficult, in fact, I know nothing about the car from a can now use the PROCEDE after about three months of hard work. In our case, I use the stock turbo a 100-200km / h@8.7s by pbox results is the fastest 335i. I will go to understand COBB, I know it will be very difficult, and there is no other better way. Thanks for your reply. |
12-06-2012, 10:58 AM | #12 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
seems like you are in over your head with this car, my friend. I've seen your threads for a while about different issues with your car...then you've added another layer of complexity by installing upgraded turbos? who installed your RB's? Is there a shop/tuning expert that can help you sort these issues? Good luck.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
12-06-2012, 11:17 AM | #13 |
3442
Rep 79,211
Many Cobb's and DME's are sent overseas without a problem, you just have to be willing to pay the shipping cost.
For the procede experts, isn't their a way to change the fuel tables within to compensate for extra OL fueling, or is that only with the flash? BTW if your scroll over the graph, make sure you are actually exceeding 34%, because when PROcede does the graphing it makes it look higher then it really is. Last edited by Jeff@TopGearSolutions; 12-06-2012 at 11:22 AM.. |
12-06-2012, 02:12 PM | #15 | ||
Rep 1,551
True, but flexibility and home concenience (to go back to stock, or alter additional tables) comes with the Cobb. Pending the user is willing to learn. |
12-06-2012, 02:26 PM | #16 | |
Rep 1,708
Rail pressure won't matter really, because in the end its volume that will determine fault. Actually lower pressure would be better cause gives OL a larger volume range (per OL value) since the percentage change would be greater. |
12-06-2012, 09:12 PM | #17 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
Op aren't you using the equivalent of 91 octane here in the states? This won't help matters...
12-06-2012, 09:31 PM | #18 |
Rep 2,172
haha, just buy the COBB AP... Then download the BMS flash. Flash your DME and then run the PROcede in Map 4 with Meth. (Thanks Terry)
There's a guy in Texas that is running COBB & PROcede. He may be able to provide help if you can figure out who. I can't remember his online name off the top of my head. |
