Can't break free front O2 sensor on Dp install
12-06-2012, 04:12 PM | #1 |
Rep 329
Hey,
I can not get the o2 sensors to break free!! I have an oem crows foot that I reneted and also have tried using a wrench, no luck with either. I hit it with some pb blaster and will try again tomorrow A.M. Are they reverse threaded? Any Ideas or suggestions on how to loosen these suckers? Ive searched on the forum and havent found anything. Thanks |
12-06-2012, 04:25 PM | #4 |
Rep 439
Try an adjustable wrench and use some man muscle
2011 335is "Redrkt" 6 MT
DocRace 6266 Single Turbo - Fuel it stage 3 LPFP - Fuel it PI - spec stage 3+ clutch - mfactory SM flywheel - 100% E85 - VRSF 7.5" intercooler - VRSF charge pipe w/ HKS BOV - JB4 - MHD back end flash 768 whp 695 ft lbs - E85 - 32PSI |
12-06-2012, 04:28 PM | #5 |
Rep 329
Well damn... Alright then. Ill eat my wheaties and go to town.
I'm a pretty big guy and was pulling off the front bumper for more torque. Ill just keep at it. Thanks! |
12-06-2012, 04:30 PM | #6 |
OPN DIFF
479
Rep 1,912
Drives: 10' E90 M3 6MT LB
Give it a good wack on the wrench with a hammer.
12-06-2012, 08:20 PM | #11 |
Rep 2,396
Drives: '08 E90 335i
Blow torch & some muscle should loosen it up. The longer wrench you can use, the better (it'll help generate torque)
12-07-2012, 10:15 PM | #12 |
Rep 329
Thanks for the input! O2 sensors out new down pipes in but not yet finished. They are touching in several places, both each other and the vehicle. From every install thread ive read they say start with the turbo end and attach the vband clamps, so that is what I did. Going to try in the A.M. to loosen the clamps, which are not tight just in place, and attach the midpipes in hopes that they will help guide the pipes to the correct place.
12-07-2012, 10:32 PM | #13 |
Mad Linux Guru On The Loose
1130
Rep 5,400
I hate to admit it, but benzy is correct. Heat it up the bung area of the downpipe with a blow torch. The metal will expand and loosen up its grip on the sensor. Just make sure you do not burn your sensor though...
12-08-2012, 02:27 AM | #15 |
DIYER
614
Rep 5,521
Tool I made in 2 minutes and LOVE it LOL!!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
12-08-2012, 10:36 AM | #17 |
adrenergic stimulation
Rep 405
that is the same tool I made but a 22mm and works awesome. leverage with a long bar is the best for stubborn nuts/bolts.
