Dinan Oil Cooler line leak
12-10-2012, 10:04 AM | #1 |
Rep 77
I was driving my car this weekend when I got a warning message saying oil level below minimum. I parked the car and when I came back out the next morning there was a pretty substantial puddle of oil on the ground at the right front of the car. I checked under the hood and it appears that the lower braided line going to my oil cooler has rubbed against the radiator fan shroud and rubbed a hole through the oil line.
I was just wondering if anyone else on here has had similar issues and if I can just replace it with a standard hose from somewhere like Jegs or if I would need to purchase a replacement from Dinan. I'm sure it won't be cheap from Dinan. |
12-10-2012, 05:52 PM | #2 |
Life is better with burnouts
99
Rep 611
No you should be fine with oil line from jegs. Try buying hose that is the same brand as your old hose and fittings. If you cannot find the brand buy the appropriate size from jegs.
12-10-2012, 05:56 PM | #3 |
Rep 967
Had the same problem with my CP-E oil cooler, I have rubbed through twice, the second time flooding my garage with oil. My mechanic was in there for another job and ran some reinforced lines and *knock on wood* haven't had any issues since.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
12-10-2012, 06:30 PM | #4 |
Rep 3,396
I just check my Dinan oil cooler lines and can't see how they would be rubbing against the fan. Both lines are tied together and sit outside the fan shroud cover that is between the spinning fan and the oil lines. Then again I did have my unit installed by a Dinan dealer so maybe that's why I have not had an issue since installed. Maybe my shroud cover is different?
12-10-2012, 06:46 PM | #5 |
Rep 1,708
I actually just had a convo with ER about this and their recommendation was to keep the oil lines secured to the engine since it will move separate from the shroud/body. I don't really see a good area to secure "away" from the shroud. OP is your line NOT attached to the shroud, but loose in that area and rubbed over time?
12-10-2012, 07:07 PM | #6 | |
Rep 4,392
If it has been more than 2 years from the install or not installed by an authorized Dinan dealer then do some shoping around on prices |
12-10-2012, 07:11 PM | #7 | |
Rep 77
12-10-2012, 07:16 PM | #8 | |
Rep 77
I read a post that ar design oil coolers have had similar issues and that whenever anyone has this issue they send them the braided SS lines for free. I wish Dinan would do the same. |
12-10-2012, 07:49 PM | #10 |
Rep 4,392
Did you ever talk to Dinan about the issue ?
12-10-2012, 08:07 PM | #11 |
Rep 77
No not yet. I wrote them an email today but haven't received a response. I'll call tomorrow if I haven't heard back. This was Steve Dinan's personal car so maybe they will do me a favor and send me one for free.
12-10-2012, 08:18 PM | #12 |
Rep 3,396
I bet they send you new cables free, Dinan is a very reasonable company especially Steve or Scott are very customer oriented.
12-10-2012, 08:20 PM | #13 |
Rep 77
12-11-2012, 10:47 AM | #15 |
Some dude
92
Rep 1,780
You can use something as simple as a zip-tie "bridge" to separate hoses and make routing easier. Wrap a large zip-tie around both hoses, leave it loose, then wrap another zip-tie around the first zip-tie in between the hoses. Tighten them both up and trim the ends flush.
I've seen the same rubbing on a customer car years ago. It was over $100 for the pair of hoses, but we managed to catch it before it became a problem. You can get anyone who makes hydraulic lines to put new hose and crimps on. Might be cheaper than if you have to pay for the hoses out of pocket. But I'd ask the guys at Dinan to help out, since it was obviously their install. He said that 335 was for his wife, but I've heard stories of him doing some interesting demo rides with it.
RRT
E92 335i/6MT with stuff and things |
12-11-2012, 11:56 AM | #16 |
Rep 4,392
Aha the white E92 ? If so they will take care of you. To speed things up for you I PM you another contact person there who can help you
12-11-2012, 12:25 PM | #17 |
3442
Rep 79,211
Rubbing oil lines is a common culprit with aftermarket oil coolers. I recommend all people with aftermarket oil coolers to double check their installs. This could be a disaster waiting to happen for some. A quick zip tie is all that is needed to avoid this in the future.
12-11-2012, 01:32 PM | #18 |
Rep 77
12-11-2012, 06:09 PM | #19 | |
Rep 77
Apparently the line is $212 from Dinan. So I think I'll just find one from another source because I know I can find it cheaper than that. Last edited by BadKarma22; 12-11-2012 at 06:15 PM.. |
12-12-2012, 10:31 AM | #20 |
Rep 2,563
I had the same issue about one year ago with my AR Design oil cooler. Oil leak while driving to a week-end holiday, not fun having to have it towed back.
The oil lines delivered with aftermarket oil coolers are usually low-quality braided ones that I've already seen leaking in other cars as well. I would always recommend to replace them with proper steel dash lines, even if that obviously is quite expensive. The advantage is that they're basically indestructible and also do not expand so much under pressure and heat as the braided ones. Dash lines are also habitually used in motorsport applications for these reasons. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
02-20-2013, 05:39 PM | #21 | |
DIYER
614
Rep 5,521
http://www.e90post.com/forums/showthread.php?t=806401
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
02-21-2013, 09:01 AM | #22 |
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
I had a similar issue with my ER Sport cooler - one of the fittings was defective initially, and then one of the hoses got itself looped up against the intercooler (mine is an ETS unit) T-clamp where it meets the turbo output. I replaced the nylon braided hoses with steel braided units, double-checked the installation instructions, and then used several tie-wraps to keep the lines together and routed away from the intercooler piping and the screws that hold the plastic underpan on (they have sharp points that protrude into the space where the lines are). And yes, it is possible to replace the lines without pulling the bumper - just remove the plastic underpan completely and you'll have access to the fittings on both ends. I got new ones from ER, but you should be able to buy aftermarket lines with the correct fittings. Just make sure they're exactly the same length and fitting types as the originals or you may encounter some line routing issues.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey Last edited by RoundelM3; 02-21-2013 at 09:08 AM.. |
