E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Dyno Run. '06 e90 325i 6MT, Graph & Pictures
Reply
      11-18-2005, 06:49 PM   #1
Guess
BlackBerry King
41
Drives: 2009 BMW 335i
Here is the dyno that was done today by vibrant. Completely stock BMW 325i, same vehicle that pulled a 14.7 in the 1/4 mile.
201 whp
182 wtq
Very impressive numbers for a stock BMW.
pictures:
2009 BMW 335i /6 SPD Fully Loaded Saphire Black on Black Dakota Leather
      11-18-2005, 06:53 PM   #2
res_ipsa
res_ipsa's Avatar
14
Drives: 325i SparkGraphite
Thanks for sharing Guess. I'm impressed by those #'s.
Go 325i !!
      11-18-2005, 07:00 PM   #3
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
Nice!!
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      11-19-2005, 12:52 AM   #4
tightie
JOSH SHOKRI.
tightie's Avatar
Drives: 991 GT3RS, 964, Raptor
2008 BMW M3  [7.90]
niceeeeeeeeeeee.
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict
      11-19-2005, 10:45 AM   #5
Silver 325i
Drives: 2006 E90 325i
Does anyone know what a stock e46 330i does?
      11-28-2005, 10:35 AM   #6
Sho
Sho's Avatar
35
Drives: E90 325i 6-speed
Nice..over 200 WHP stock.
      11-29-2005, 07:11 PM   #7
ma1kmcn1
Drives: 2011 Interlagos Blue E93 M3
Doesn't 201 whp seem too high? The 325 is 215 bhp and that would mean only 14 hp lost through the drivetrain?
      11-29-2005, 07:32 PM   #8
lbernielu
Drives: 2006 330i, sp, Bilstein, H&R
215 horsepower means that all the motors are guaranteed at least that amount, and some will have more just due to normal variations. Also, BMW may have delibrately underrepresented the horsepower a smidgen, so 201 sounds accurate.
      11-29-2005, 08:14 PM   #9
ACZakka325i
ACZakka325i's Avatar
278
Drives: 2 stroke
also take into consideration that the engine will not produce full power until it is fully broken in. on my e46, it really started to shine around 20,000 to 30,000 miles. sadly, the lease was up right around this time!
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe
(Past): 2016 F30 340xi M-Sport -2013 535i xdrive
2008 E92 M3 - 2006 E90 325i
2002 E46 325xi - 1991 E30 325i
      11-30-2005, 12:03 AM   #10
visor
BMW, can I have some LSD please?
visor's Avatar
Drives: 2017 F30 340i xDrive
201/215 = 6.5% drivetrain losses.
This is pretty much in line with the previous E46. BMW manuals and drivetrains are quite efficient!
So that means the E90 330i should be around
93.5% x 255 = 238hp at the wheels!
Compare that estimate with IS350. Assuming a conservative and most likely auto tranny loss of around 15%:
85% x 306 = 260hp at the wheels.
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired
2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired
2017 340i xDrive | Estoril | Black | Al | 8AT | M Package
      12-02-2005, 11:17 AM   #11
england1987
Drives: Z4 M coupe
2006 Z4 M Coupe  [7.50]
thanks
Thats cool. good pics
      12-04-2005, 05:41 PM   #12
ed328ci
Grumpy
12
Drives: E90 325i
Considering that stock 325i have to tested to be only slightly slower 0-60 and 1/4 verses the 330i, people have speculated that BMW have purposely advertised lower hp and torque rating for the 325i. Remember the only powertrain differences between the two models in North America, are the intake system and the engine software.
Ed
      12-04-2005, 05:49 PM   #13
visor
visor's Avatar
Ed
If your theory is correct, then it is beginning to make sense regarding the much-rumored 2007 328/335 models that will replace the current 325/330.
      12-04-2005, 06:08 PM   #14
tctic
Drives: BMW E90
Any Dyno runs on the real 2.5L engine? Then now, we can compare.
      12-14-2005, 04:17 PM   #15
ward
Drives: F
looks bad to me to have those metal hooks tied down on your nice soft aluminum control arms
you should have an alignment check as they may be bent now
(aluminum suspension is also why you can't just tow a BMW using standard methods)
      12-17-2005, 09:30 PM   #16
gdcwatt
Drives: 2003 Mazda Protege
tctic - I'd like to see the torque curve of the 323i, too. This engine's 3750 torque peak is a full 1000rpm higher than the 325/330, and I wonder what's available at, say, 2000rpm? We KNOW that the 330i has useful torque from, at least, 2750 to 7000rpm. I don't even know what the 323i redlines at, but the hp peak is at 5750.
I think that, as a percentage, drivetrain losses for a 323 would be greater. Shaving 5 lbs off each drive wheel, with some lightweight rims, would benefit this car especially, across the entire powerband.
      12-17-2005, 09:41 PM   #17
ed328ci
Grumpy
12
Drives: E90 325i
No. It's on a North American 325i, which has a detuned 3.0 L engine.
Ed
      12-18-2005, 10:26 AM   #18
D-Rock
Drives: 325i
Whats does wtq stand for ?
      12-18-2005, 01:58 PM   #19
shadye90
shadye90's Avatar
60
Drives: BMW Fanatic
The amount of torque measured at the wheels..WheelTorQue..
1988 E30 M3
Diamantschwartz/Black
      12-18-2005, 02:13 PM   #20
D-Rock
Drives: 325i
o thanks
      12-19-2005, 11:56 AM   #21
JPM8220
Drives: 05 E90 325i
Personally I don't believe to the most of dyno results.
Because the calibration of these kinds of dyno machines are really important. Also who made the calibration & Is he sufficient to do the calibration ?
It's normal to obtain less Hp (max. 10) but not a %15 loss
      12-19-2005, 03:14 PM   #22
tctic
Drives: BMW E90
Ed
I know in NA, the 325i has a detuned 3.0L engine. But since the 'real 2.5L' outside of NA are quoted the same HP/Torque numbers by BMW. I was interested in seeing and comparing the 3.0L engine 325i vs. 2.5L engine 325i.
Reply
e90post
