What kind of ECU chip do I have?
12-13-2012, 10:51 PM | #1 |
Rep 87
I bought a preowned 2007 335i e92 coupe recently. It's fantastic. But in the glove box, there's a USB cord that looks permanently attached running from the glove box, to inside the fuse box and maybe leading into the ECU/DME box.
Is there any way to find out which ECU chip I'm running, like a menu screen I could activate from inside the car? I've already tried: plugging it in to my MacBook pro and nothing happened, there's no way I could contact the previous owner, and I would prefer not to go through the hassle to open the ECU/DME. Please help! |
12-13-2012, 10:56 PM | #2 | |
Rep 965
Drives: e92 m3
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
12-13-2012, 11:04 PM | #4 |
Rep 961
People running piggies will usually route the USB cable through the glove box to hook it up to a laptop.
OP, just take the 10 minutes to open the DME compartment. Ohh, and it's not a "chip." I know don't know the last time i've seen an EPROM or EEPROM ecu.
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
12-13-2012, 11:20 PM | #5 | |
Rep 2,396
Drives: '08 E90 335i
You're in CA, so if you try the regional thread I'm sure one of the more experienced piggy-back users wouldn't have a problem helping you open everything up to confirm. |
12-14-2012, 08:24 AM | #8 |
Rep 639
Try pushing down on the down arrow and minus buttons on the steering wheel at the same time (while the car is running). If your gauges move, you have a JB4. If not, you need to open up the DME box to look.
12-14-2012, 09:28 AM | #9 |
Some dude
92
Rep 1,780
To check for JB4: Push the volume down and arrow down buttons on the steering wheel at the same time with the engine running or not to enter the command mode. The tachometer and speedometer needles will move to 1000RPM and 10MPH to indicate you're in command mode.
To check for Procede: Push the cruise control stalk up or down with the engine running to see what map the engine is running. Pull toward you with the engine off but ignition on to enter command mode. If neither of these work, the JB or Procede may have been removed but the cable left in place. You will need to open the ECU box to find out. And they're not "chips" anymore, it's more commonly referred as a "tune", whether it's a piggyback or a flash.
RRT
E92 335i/6MT with stuff and things |
12-14-2012, 10:02 AM | #10 | |
3442
Rep 79,211
Getting to the actual ECU compartment should not be scary.
There are about 8 8MM bolts to remove the cowl and HVAC Filter. Then 2 tabs on the ECU cover to remove it. Then you can visually see what is going on. Quote:
12-14-2012, 10:30 AM | #11 |
Rep 2,013
Easiest way to tell is what he said^^
For jb4: push volume and channel control down at same time to see if gauges move. For procede push criise control up or down to see if gauges move. For jb3: if you really dont want to access the ecu....go on youtube to learn how to switch maps with the gas pedal...you should "feel" the extra power. Imo: open the ecu, its easy. |
12-14-2012, 10:36 AM | #12 |
Rep 3,261
dont get your hopes up.
On my old 335i i took the tune out but didn't bother wasting time to take the guts of the ecu box out just to yank out the USB cable.
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
12-14-2012, 11:57 AM | #13 | |
Rep 2,013
Gets his hopes up for a free tune but all he gets is an usb cable lol |
12-14-2012, 12:21 PM | #14 | |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
now the OP has to assume the original owner didn't/did abuse the car with the tune, if it really had/has one.
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
12-14-2012, 07:35 PM | #15 |
Rep 87
Alright, by JamesM3M5's methods, I don't have JB4 or Procede.. I'm starting to think that the previous owner took out the tuner and left the cable like TurboSid said, damn. Looks like I'll have to open the DME up to find out for sure
12-14-2012, 08:49 PM | #16 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
Too bad, was hoping you'd get a free tune out of it! Well, now you need to buy one to see what you're missing.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
